GNC-300XL IFR GPS/COM
Old October 15th 03, 07:44 PM
Mark Astley
Well in my particular case, the radio I'm replacing is a narco with a narco
glideslope head that won't work with my other nav/comm (a KX-175B). So I'd
have to buy two heads if I wanted to fly a precision approach: one for the
new GPS, and one with a glideslope needle (I DO have a KI201C currently on
my KX-175B but, even if that would work for the GPS, I'd still need to buy
the annunciator, etc). I opted to buy just one head with a glideslope
needle and share it between the GPS and my nav/comm. En route, I certainly
wouldn't be using both at the same time, and I couldn't think of any
approach situations where I'd need a CDI for both. If you're not in this
particular situation then yes, it makes better sense to buy the MD-41
combination.
mark
"Stu Gotts" wrote in message
So maybe I'm missing something and hope someone can explain it to me.
If you need an indicator for an IFR box, why not a dedicated
indicator? One with the warn lights, etc., that would not be shared?
Wouldn't that eliminate the need for a switching device? Which ones
would qualify? KI209A, etc.?
On Wed, 15 Oct 2003 05:39:24 GMT, "Flynn"
I installed this unit as the number two in my previous plane (number one
was
a kx-155 w/GS). I thought it was a great budget unit. $2400 on ebay
from
JA Air. All in including certification I was out $6800. Having now
flown
behind a pair of 430's for 25 hours, I still think that the set up above
was
perfect for a 79 Grumman.
"Jeff P" wrote in message
. com...
Anyone have any experience with the GNC-300XL IFR GPS/COM?
Does it work well? Do you like the user interface? How is the
screen?
I want to have GPS IFR capability in my 172. What else will I have to
install to get IFR cert for this unit?
Jeff
Old October 16th 03, 12:30 AM
ROBIN FLY
combination.
mark
Mark:
With your setup, if you want to use MD-41, you still need a KN-72 converter to
convert KX-175B's composit NAV to right-left for MD-41, and you would not have
GS nuless you also get a KN-75 GS receiver.
If you want to share a CDI for both KX-175 & GPS, KI-209A is your best choice
because KI-209A has built-in converter & relay switching for GPS/NAV signals.
You still need a GS receiver like KN-75 to get ILS, and annunciators/switches
to control GNC300's arm, hold functions as well as switching KI-209A between
GPS/NAV signal by grounding a wire from KI-209A.
All these extra hardwares and installation make GNS430 a batter and not much
more $ choice. Been there & done that with KX-125, KN-75, Trimble 2000,
KI-209A, and MD-41 (I get GPS on both KI-209A & MD-41). I did my own
installation so I saved by using used first gen GPS, but if I need to pay
someone to install for me, GNS430 with single CDI will be my choice.
Robin Hou
Old October 16th 03, 07:44 PM
Mark Astley
Robin:
I basically did what you suggested except I chose a garmin head rather than
the king head. So the extra parts I'm getting are the garmin head, the
KN-75 for glideslope, and an AmeriKing annunciator/switch. And you're
right, that does add to the cost, but everything included I'm still about
$2K shy of a new 430 install. I can't remember if I already mentioned this,
but I looked into the used 430s and couldn't find a 14v unit. I was advised
against using a 28v unit with a converter because apparently the converter
fails often.
If anyone has any experience, good or otherwise, with one of the 28v 430s
with a converter, I'd like to hear about it.
mark
"ROBIN FLY" wrote in message
snip
Mark:
converter to
have
choice
signals.
between
much
Robin Hou
Old October 17th 03, 06:21 PM
Paul Lee
If you do not already have an RNAV unit, you could use Narco 122D/GPS
that can share its indicator with the 300XL. I had to go that route
to save panel real estate.
The 300XL requires a CDI with a resolver (not a converter).
The Collins 350 CDI has a resolver and will fit the
300XL.
Paul Lee, SQ2000 canard project: www.abri.com/sq2000
"Mark Astley" wrote in message ...
have to buy two heads if I wanted to fly a precision approach......
Making a VFR C152 IFR Paul Folbrecht Instrument Flight Rules 48 April 7th 04 04:39 PM
