looking for a wheel brake solution
Old April 12th 11, 12:05 AM posted to rec.aviation.soaring
Bob Luten
Default looking for a wheel brake solution
any thoughts/suggestions? *Thanks!
I replaced the 4-inch wheel with drum brake on my Apis with a Tost
Tria wheel with disk brake. See http://www.wingsandwheels.com/pdf/Tria.pdf
for a description.
-- Bob --
Old April 12th 11, 02:35 AM posted to rec.aviation.soaring
Tony[_5_]
Tria wheel with disk brake. *Seehttp://www.wingsandwheels.com/pdf/Tria.pdf
for a description.
* -- Bob --
interesting, do you remember what you paid for it? Otherwise I can
always email Tim, or he might chime in here.
Bob K - 5.00 x 5 would be ideal since that is a very popular airplane
size. Dean Gradwell converted his very nice Cherokee II to take a
5.00 x 5 tire for that reason, so it can be done. My constraint that
is driving me away from that is that it seems that a 5" wheel requires
a 3/4" axle and Leah's Cherokee is currently set up for a 5/8" axle.
Not impossible to convert but would require fabrication of new
fittings and some tearing apart and rebuilding. I have enough of that
to do the way it is. 4.00 x 4 aircraft tires are available from
Desser so there shouldn't be much of an issue getting them. Prices
are semi reasonable too.
Old April 12th 11, 03:07 PM posted to rec.aviation.soaring
for a description.
* -- Bob --
interesting, do you remember what you paid for it? *Otherwise I can
size. *Dean Gradwell converted his very nice Cherokee II to take a
5.00 x 5 tire for that reason, so it can be done. *My constraint that
fittings and some tearing apart and rebuilding. *I have enough of that
to do the way it is. *4.00 x 4 aircraft tires are available from
Desser so there shouldn't be much of an issue getting them. *Prices
You may want to consider using 5/8 axle and making a sleeve of .062
wall tubing to get to size required for bearings. We do this on 1-26's
so we can use more readily available bearings.
UH
Old April 12th 11, 03:53 PM posted to rec.aviation.soaring
Tony[_5_]
UH
Hank,
yea, Pete made that suggestion last night offline which caused me slap
my forehead. duh! Anyway i looked at some 5" wheels this morning and
lo and behold matco actually has one with a 5/8" axle, I had missed it
apparently the last time I looked.
http://www.matcomfg.com/W50CC62D-idv-2350-29.html
Now I just have to check the width I have available, it might be tight.
SZD-55 Wheel Brake Adjustment WDM Soaring 2 January 20th 11 09:25 AM
looking for wheel/tire/brake Brad[_2_] Soaring 1 July 29th 10 02:56 AM
SZD-55 Wheel Brake David Pye[_2_] Soaring 4 September 19th 07 03:10 AM
SZD-55 Wheel Brake David Pye[_2_] Soaring 0 September 18th 07 06:01 PM
Wheel Brake on G102 Ken Pruchnick Soaring 4 March 2nd 05 07:01 AM
