#11
![]() Hankal wrote: Hope you did not forget that you have a radio. You could call unicom or any aircraft on the ground to render assistance. And if you can't raise anyone on the ground, you could probably get someone in the air nearby to land and help you out. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
![]() "John Galban" wrote in message m... I was able to get out by using a screwdriver blade to push the baggage door latch (on the door) out of the slot (on the airframe). It was visible from the inside of the baggage compartment. On my bird, the baggage door latch is simply turned into the slot by the key. Is your Archer different? You've not had real fun until you snap the canopy cable on a Navion and get it stuck in the flight open position (about 8 " open) where it won't go either way. Fortunately, I could get the pin up with a pair of needle noses that I carry onboard. There is a cute little "unauthorized" modification to provide a backup to pull the pin out there. |
After reading this thread I decided to put a multi-tool into my headphone
bag just in case MY Archer decides not to let me out. This also got me thinking about something an instructor once said to me while we were pre-flighting a 172. After I locked the baggage door per the checklist he admitted he didn't totally agree with it. He preferred to have an extra out if both main doors were jammed by a crash. At the time I thought Cessna was trying to prevent some little kid from crawling into the baggage compartment and making a tragic exit. John mentioned using a screwdriver to open the baggage door from inside. Is this easier if the baggage door is latched but not locked? Does locking actually make the baggage door more secure in flight? -- Regards, Mike http://mywebpage.netscape.com/amountainaero/fspic1.html "PaulaJay1" wrote in message ... Had a potentially bad experience in my Archer tonight. Wife and I flew to dinner and returned to the home port about 5:20. Airport normally is open till sunset (which is 5:07 tonight) but as we taxied in, the lights in their cars went out and they came walking to my plane. I store in the big hanger and they came back to open it and put the plane away. I had ment to leave it out and have them put it away in the morning. Well, little wife is saying she can't open the door. I called to Don, the owner of the FBO, and he came over and tried the outside but couldn't get it open. It was then that I realized that the door had locked on its own. No way to unkock/open it from the inside. I passed out the key through the pilot window and they unlocked the door. Later I looked at the luggage door and there is no simple way to open it from the inside either. If we had landed a couple minutes later, they would have been gone and I would probably have a slightly broken plane. I'll never argue high wing/low wing but I have become an advocate of TWO doors. Chuck |
"Mike Noel" wrote in message ...
snip John mentioned using a screwdriver to open the baggage door from inside. Is this easier if the baggage door is latched but not locked? Does locking actually make the baggage door more secure in flight? I'm beginning to think that some baggage doors may not be as simple as mine. Recalling my rental days, I seem to remember that some planes have both a latch and a lock. My baggage door(and most of the earlier Cherokees) has a single rotating locking/latching mechanism. Turn the key and a little tab on the lock rotates into a slot on the airframe. Then you remove the key. On a door with a separate latch, you might have to do some disassembly to get the latching mechanism to release. I imagine this might be a bit more difficult if the door was locked as well as latched. John Galban=====N4BQ (PA28-180) |
In article , "Mike Noel"
writes: After reading this thread I decided to put a multi-tool into my headphone bag just in case MY Archer decides not to let me out. This also got me thinking about something an instructor once said to me while we were pre-flighting a 172. After I locked the baggage door per the checklist he admitted he didn't totally agree with it. He preferred to have an extra out if both main doors were jammed by a crash. At the time I thought Cessna was trying to prevent some little kid from crawling into the baggage compartment and making a tragic exit. John mentioned using a screwdriver to open the baggage door from inside. Is this easier if the baggage door is latched but not locked? Does locking actually make the baggage door more secure in flight? Follow up on my experience of being locked in my Archer. Well, I went to the airport today with tools in hand to see what's up. I can't recreate the problem! I took off the inside panel of the door and looked at how the lock works. I can't get it to lock from the unlock position after trying various to remove the key half way between lock and unlock etc. I just don't see how it happened but it did and also to 4 others re the responses to this thread. The locking bar just won't do its thing in the unlock position. So here is what I've done to see that I have a fix if it ever happens again. The lock bar is held to the lock cylinder by a screw. When the lock cylinder is in the lock position, the lock bar is such as to keep the latch from going into the open position. So, if you remove the lock bar, you can open the door when the lock cylinder is in the lock position. I have marked (actually cut a small slit) in the inside panel at the spot over the screw that holds lock bar. If the imposible happens again, I can insert a Philips screwdriver into the slit and remove the lock bar from the lock cylinder. Vowalla, I'm delocked (that is, I'm out and have no lock/unlock capability) till I take off the inside panel and reattach the lock bar. Caution, with the lock bar off, the lock cylinder can come out the outside. In addition, I looked at the baggage door to see if it would make a good emergency exit. Same lock/unlock there with a lock bar attached to the lock cylinder. However, after removing the screw that holds the lock bar(after removing the inspection cover) you still have to "push" the button to open the door. This isn't easy since you are on the wrond gide of the button. With a screw driver you can wedge under the button and pull it toward you to unlatch the door but it ain't easy. If you want to get out this way, better check before needing the info. Chuck |
Need Cessna Door | Dale | General Aviation | 0 | December 15th 04 01:20 AM |
Air Force radios jam garage door openers THE ASSOCIATED PRESS | Otis Willie | Military Aviation | 1 | May 21st 04 01:13 PM |
wanted: hangar door tips | Joa | Home Built | 35 | April 18th 04 02:19 PM |
Blue Angel's Gear Door Broken? | Clay N4AOX | Military Aviation | 15 | October 6th 03 08:01 AM |
'50s Cessna Door Handles | Jim Weir | Owning | 8 | July 16th 03 11:01 PM |
