One door
Old December 27th 03, 11:56 PM
PaulaJay1
Default One door
Had a potentially bad experience in my Archer tonight. Wife and I flew to
dinner and returned to the home port about 5:20. Airport normally is open till
sunset (which is 5:07 tonight) but as we taxied in, the lights in their cars
went out and they came walking to my plane. I store in the big hanger and they
came back to open it and put the plane away. I had ment to leave it out and
have them put it away in the morning. Well, little wife is saying she can't
open the door. I called to Don, the owner of the FBO, and he came over and
tried the outside but couldn't get it open. It was then that I realized that
the door had locked on its own. No way to unkock/open it from the inside. I
passed out the key through the pilot window and they unlocked the door. Later
I looked at the luggage door and there is no simple way to open it from the
inside either. If we had landed a couple minutes later, they would have been
gone and I would probably have a slightly broken plane. I'll never argue high
wing/low wing but I have become an advocate of TWO doors.
Chuck
Old December 28th 03, 12:11 AM
Hankal
I never knock a low wing.
I love my Cessna 172 because I can in easier, my wife can get in without fear.
Also two doors are nice and windows in each make for good ventilation.
Hank
Old December 28th 03, 02:30 AM
Jay Honeck
How could the door lock itself?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 28th 03, 03:02 AM
BTIZ
time to replace that lock..
BT
"Jay Honeck" wrote in message
news:tfrHb.675095$Tr4.1693122@attbi_s03...
inside.
Jay Honeck
Iowa City, IA
Pathfinder N56993
BTIZ
Cessna's are also good for a rain cover when getting in and out..
BT
"Hankal" wrote in message
fear.
Hank
Old December 28th 03, 04:00 AM
john smith
Wear and vibration.
Just like other things.
If you use them, they gradually lose their original shape.
Apply the right frequency and they move without direct contact.
(*Deliberately worded for multiple meanings. :-)
Old December 28th 03, 02:41 PM
Mike Spera
How could the door "lock itself"? Good question, and one that I asked
myself when it happened early on in our ownership of the 74 Cherokee
140. These "file cabinet locks" used in Pipers (and many other birds)
have quite a bit of "slop" in the cylinder and pins. So much so, that it
is entirely possible to remove the key from my door lock in ANY
position. Normally, the key should only go in and be removed when the
lock is horizontal, either locked or unlocked. With nearly 30 years of
wear (and we only have 2500 hours TT), the key can be removed from any
position.
Why is this important?
If you unlock the door and, upon removing the key, twist the lock BACK
towards locking some distance, the key can still be removed AND the door
still opened. That leaves the lock cylinder somewhere in the middle.
All it takes is enough vibration to rotate the lock cylinder a little
bit towards locking and viola! The door is now magically locked. If I
recall, you SHOULD be able to get out using the inside door handle.
However, there is one lonesome sheet metal screw in the lock linkage
that can work loose. Once done the door will appear to work normally,
but there is not enough travel in the mechanism to open the door IF the
outside lock is locked. Once we tightened up all the internal linkages,
it allowed us to exit even if the cylinder is locked. 8 years later, the
problem had not returned.
We looked pretty silly on that hot July afternoon taxiing around trying
to find someone to let us out of that VERY hot airplane!!
BUT, that said, it is possible to lock yourself OUT of the plane once
things are working properly. If you don't unlock the cylinder all the
way (as I described above), leave the keys inside, and then EXIT the
bird and close the door (remember that the inside handle will let you
out), the bird is now locked with the keys inside! IF the lock is
somewhere in the middle of its travel, you can simply turn the lock with
your fingernail to complete its travel towards unlocking (you DO
remember which way that is, don't you???). However, it is entirely
possible that the lock has vibrated towards full lock, in which case,
you need the key. When this happened to me, I used a screwdriver (well,
a key actually) on the phillips-head screw for the little vent window.
Turning the screw also turned the catch until it popped open. Once done,
I could reach in and get the keys.
Try this experiment: move the cylinder until it is vertical (pointing up
and down) or some other non-horizontal position, remove the key, and
then gently bang your fist on the door in various placed mimicking
normal flight airframe vibration. You may be amazed to see the lock
cylinder actually rotate one way or the other. Depending on the
condition of your lock, it may or may not do this. It looks a little odd
when you see it for yourself.
I now make a point of turning the lock completely in either direction
before removing the key ( or checking the work of the "other person"
should she be working the lock that day).
Good Luck,
john smith wrote:
Wear and vibration.
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old December 28th 03, 06:16 PM
PaulaJay1
position.
Mike, I think that you have a good handleG on the problem. The inside latch
did not open the door in our case. I want to do some "look around" on the door
to see what can be done to prevent it again. Making sure that the key is
completely truned against the stop is one thing and, of course, I'm not sure I
turned it full open when I unlocked the plane (before the flight down, by the
way). I also want to check the baggage door since it would be an emergency
escape and does not appear to have an inside latch or unlock ability.
I had a cell phone but I still think I would have forced the door if the other
people had not been there. Kind of an unsettleing feeling when you are locked
in, it's dark and 32 deg outside.
Chuck
Old December 29th 03, 12:52 AM
Hankal
Another good reason to always travel with a cellphone.
Hope you did not forget that you have a radio. You could call unicom or any
aircraft on the ground to render assistance.
Need Cessna Door Dale General Aviation 0 December 15th 04 01:20 AM
Air Force radios jam garage door openers THE ASSOCIATED PRESS Otis Willie Military Aviation 1 May 21st 04 01:13 PM
wanted: hangar door tips Joa Home Built 35 April 18th 04 02:19 PM
Blue Angel's Gear Door Broken? Clay N4AOX Military Aviation 15 October 6th 03 08:01 AM
'50s Cessna Door Handles Jim Weir Owning 8 July 16th 03 11:01 PM
