Can you mix oil weights?
Old January 4th 04, 12:27 AM
Ben Jackson
Skyking wrote:
The trick is to thin it with AvGas when you shut it down.
Won't the gas all evaporate out the breather tube if you pour it into
the filler neck of a hot engine?
How much gas are we talking about here, anyway?
Ben Jackson
http://www.ben.com/
Old January 4th 04, 03:30 AM
karl
****How much gas are we talking about here, anyway?*****
My Cessna 185 has a factory option for an "Oil Dilution" system. There is a
table, seconds of OD push per temperature.
This was very common in the bush, and before reliable engine preheating.
Once the oil warms up, the gasoline evaporates.
Best,
Karl
Old January 4th 04, 08:18 PM
G.R. Patterson III
So it should be added to a cold engine just before start, then?
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 5th 04, 02:51 AM
J. Severyn
"G.R. Patterson III" wrote in message
Nope. Gas is added to the warm engine oil, just before shutdown. That way
the oil is diluted and thin for the next cold start. Pretty common on
radial engined aircraft.
John Severyn
JSF/F-22 weights John Cook Military Aviation 2 September 11th 04 06:32 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
Engine weights Salem Farm & Garden Home Built 5 July 22nd 03 04:27 AM
