Can you mix oil weights?
Old January 2nd 04, 09:50 PM
Ben Jackson
Default Can you mix oil weights?
Let's say you're at a point where you need to add a quart of oil.
You've decided you would like to finish this oil change interval at
a lighter weight (eg you put in AeroShell W100, SAE-50, and now it's
freaking cold). Can you add a quart of a (substantially?) lighter
weight oil (presumably in the same 'series')?
Ben Jackson
http://www.ben.com/
JSF/F-22 weights John Cook Military Aviation 2 September 11th 04 07:32 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 07:19 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
Engine weights Salem Farm & Garden Home Built 5 July 22nd 03 05:27 AM
