Radio Removal
Old March 22nd 04, 04:04 AM
MRQB
I tried turning it a lot of times counter clockwise and clockwise it did
nothing at all did not here anything disengage the screw was very loose in
the hole maby it is broken? any other way to disengage it?
"John" wrote in message
You have the correct screw. It requires a short 1/8 inch flat blade
screw driver. However it is the cam lock screw. It does not push the
radio out. Clockwise to lock and counter clockwise two or three turns
to unlock. Generally you can feel the lock disengage. When
unlocked you must grab two of the larger knobs then shake while
pulling to remove the RT-308. The very small hole is for the VOR
centering adjustment.
Some of the other ARC radios require a 12 inch long flat blade screw
driver.
On Sat, 20 Mar 2004 22:20:23 -0800, "MRQB" wrote:
I found the screw it was right in the center lower part of the radio
below
ware it said RT 308 it was not deep inside it was really close to the
surface unless it was the wrong screw I turned it it did nothing it would
just spin either direction there was a really smaller hole next to it. Is
it
broken? or was i on the wrong screw?
"Kyle Boatright" wrote in message
In general there will be a hole in the face of the radio where you
insert
an
allen wrench. Turn the screw clockwise to release the radio.
"MRQB" wrote in message
Hello, i would like to know how to remove the Cessna ARC NAV/COM 300
radio
out of my 150? Ware are the screws bolts ect located? So I can take
it
in
to
be serviced or replaced it with a slide in replacement. I here it is
simple
to remove it, is it?
Old March 24th 04, 12:38 PM
Paul Sengupta
Probably already disengaged...try shaking and pulling...
Paul
pulling to remove
Old March 20th 04, 03:53 AM
Aaron Coolidge
MRQB wrote:
: Hello, i would like to know how to remove the Cessna ARC NAV/COM 300 radio
: out of my 150? Ware are the screws bolts ect located? So I can take it in to
: be serviced or replaced it with a slide in replacement. I here it is simple
: to remove it, is it?
There's a small hole in the bottom center of the radio. You need a regular
screwdriver 1/16" wide by 12" long to reach the screw which is in the very
back of the radio. Unscrew the screw and pull the radio out of the dash.
More modern radios use a hex key (Allen wrench), and it does not have to be
as long as the ARC radios require.
Aaron Coolidge (N9376J)
Old March 20th 04, 05:01 PM
SD
On Sat, 20 Mar 2004 03:53:10 +0000 (UTC), Aaron Coolidge
We just had to take one of these radios out of a plane the other day
and instead of buying a screwdriver that would fit in that hole, we
took a coat hanger, cut about 10 inches of it. Bent about an inch
over to act as the handle and on the other end, put it in a vice to
flatten it so that it would fit into the slot of the screw. Worked
perfect!
SD
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
Good panel mount COM radio and intercom w/push-to-talk? John Huebbe Home Built 10 November 27th 04 07:58 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
