c182 fuel burn
Old July 6th 04, 07:01 AM
BH
Rob 5/07/2004 9:21:31 pm
Can someone tell me what the fuel burn numbers are on a typical older c182
with the Continental 230hp carbed engine. I am trying to do a comparison
with a Cherokee 6/300 and can't find numbers for the C182.
Thanks, RT
My 182R (230Hp/O-470-U, factory reman) burns 53 litres/hr (~14.0 US gal/hr)
at 23/2350 at 3500'. Down to 48 l/hr (12.68 US gal/hr) at 21/2200.
Consistently. Measured by a very accurate JPI fuel flow meter. Top-up is
within 1 or 2 litres of JPI reading, out of 250/260 litres. Everyone tells
me it should be lower..... It is at 6500', with settings 20/2350 (WOFO) ~
48l/hr.
Old July 6th 04, 02:17 PM
David
Our 1979 C182RG burns on average 13.5 gph in cruise flight (based on our JPI
EDM-800)
"Rob Timmerman" wrote in message
Thanks, RT
Old July 6th 04, 06:54 PM
Javier Henderson
Jim Weir writes:
Depends entirely on how hard you run the engine. I prefer 20" and 2300 RPM
(makes for a very smooth ride) and get just under 11 gph by the clock.
What average TAS do you get at, say, 7500' with those settings?
-jav
Old July 6th 04, 07:56 PM
Jim Weir
I usually expect to see 112-115 knots depending on temperature and loading.
Javier Henderson
-Jim Weir writes:
- Depends entirely on how hard you run the engine. I prefer 20" and 2300 RPM
- (makes for a very smooth ride) and get just under 11 gph by the clock.
-What average TAS do you get at, say, 7500' with those settings?
--jav
http://www.rst-engr.com
Old July 6th 04, 08:41 PM
SeeAndAvoid
This is based on my 1970 N model with an O470R engine thats
about 100 hours beyond TBO (1500hr on R).
I have plugged in to my various flight planning programs pretty
close to what the manual says, and on refuel rarely off by a
couple gallons. I use one of those universal dipsticks and I
find that at the lower values is where I find the most errors.
Anyway, below 8,000' it seems to be around 12.5-13gph and
recently back east staying below 4,000' it was at least 13gph.
Where it shines is heading west (well, I guess direction doesn't
matter)and in the O2 altitudes, I'll get 10 to 10.5. This is always
at full throttle and 2400-2450 RPM, trueing out at 130k with the
wheel pants on, 127k with them off. EGT around 1550, burn
around a quart of oil every 13-15 hours. Although I'd love the
room of a 206/PA32, I've been very happy with this engine
and airplane.
Chris
Thanks, RT
Old July 6th 04, 09:55 PM
WinstonCup
Thanks, RT
I have a 1978 182Q with an 0-470-U (new ECI cylinders 75 hours ago) and I
flight plan 137kts @ 8,000 feet. 22" MP @ 2,200 rpm and it burns just about 12
gph. At lower altitudes and lower power settings, I burn about 11 gph. At
faster cruise power in the lower than 6,000 foot range, I burn about 13 gallons
or so.
I checked out both types prior to purchasing and these few items put me on the
side of the 182.
1. Doors on both sides (under the wing) which keeps you in the shade and out
of the rain during loading.
2. If I ever had an off airport landing and I nosed over, I can open the doors
to get out of the 182. In the 6/300 you may get trapped.
3. I rarely need more than 3 passenger capacity.
I learned to fly in Warriors (Low wing lover) and really wanted an
Archer/Arrow/ or Six...but for the money and performance I chose the 182. (It
took a long time to find the right one though)
Good Luck and whatever decision you make, it will cost more than you expected.
KC
C182Q - PP ASEL IA
Old July 6th 04, 10:00 PM
Matt Whiting
Javier Henderson
-Jim Weir writes:
--jav
Jim, is that TAS or IAS? Seems low for TAS at that altitude.
Matt
Old July 7th 04, 02:20 AM
Javier Henderson
Matt Whiting writes:
I think the power settings he mentioned are equivalent to about 60%
power, so those speeds seem OK, no?
-jav
Old July 7th 04, 03:46 PM
Jim Weir
TAS. And a correction. That's 20" and 2200 RPM, not 2300. I didn't notice
that typo until I went back to see why you might think this a bit low.
Matt Whiting
-Jim Weir wrote:
- I usually expect to see 112-115 knots depending on temperature and loading.
- Jim
-Jim, is that TAS or IAS? Seems low for TAS at that altitude.
-Matt
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Repairing Plastic Instrument Panel Overlay Jeff P Owning 22 January 29th 04 06:42 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
