c182 fuel burn
Old July 5th 04, 02:21 PM
Rob Timmerman
Default c182 fuel burn
Can someone tell me what the fuel burn numbers are on a typical older c182
with the Continental 230hp carbed engine. I am trying to do a comparison
with a Cherokee 6/300 and can't find numbers for the C182.
Thanks, RT
Old July 5th 04, 02:30 PM
Dave S
Thanks, RT
The 182 (1963 C model I think) in the Bay Area Aero Club bills its
members at a wet rate based on a 13 Gpm fuel burn. This burn rate is
based on actual usage and is surveryed quarterly. I cant account for how
much of this is training (and richer mixtures) versus XC (and hopefully
leaner mixtures). The aircraft has been in the club for about 2 years,
and newsletters may show some variation in the fuel burn.
All may be found at www.bayareaaeroclub.org
Dave
Old July 5th 04, 03:19 PM
Dude
Is that 13 gph based on tach or hobbs?
"Dave S" wrote in message
ink.net...
c182
Thanks, RT
Dave
Old July 5th 04, 10:15 PM
Dave S
Hobbs.. Good question and sorry I didnt specify earlier. Maybe it wasnt
much in the way of good info after all.
Dave
ink.net...
c182
Thanks, RT
Dave
Old July 5th 04, 02:45 PM
Aaron Coolidge
: Can someone tell me what the fuel burn numbers are on a typical older c182
: with the Continental 230hp carbed engine. I am trying to do a comparison
: with a Cherokee 6/300 and can't find numbers for the C182.
: Thanks, RT
Rule of thumb for piston engines: divide rated HP by 18 to get cruise
fuel flow. Assumes about 75% power and proper leaning.
IE, 230 HP is about 12.7 gal/hr.
Aaron Coolidge
Old July 5th 04, 09:29 PM
Bob Miller
FWIW
180 hp M20C (carb'ed) run 600 hrs mostly x-c at 75% 9.5-10 gph cruise
trips of 1.5-2.5 hours typical
Flight Fuel Flow average 9.1 gph (total fuel / flt time) as measured
by Garmin 196
Tach Fuel Flow average 8.5 gph (total fuel / total tach)as measured by
Horizon electronic tach
No Hobbes to compare
YMMV
Old July 5th 04, 04:22 PM
Jim Weir
Depends entirely on how hard you run the engine. I prefer 20" and 2300 RPM
(makes for a very smooth ride) and get just under 11 gph by the clock.
"Rob Timmerman"
-Can someone tell me what the fuel burn numbers are on a typical older c182
-with the Continental 230hp carbed engine. I am trying to do a comparison
-with a Cherokee 6/300 and can't find numbers for the C182.
-Thanks, RT
http://www.rst-engr.com
Old July 5th 04, 05:02 PM
Mike Adams
2300 RPM (makes for a very smooth ride) and get just under 11 gph by
the clock.
"Rob Timmerman"
older c182 -with the Continental 230hp carbed engine. I am trying to
do a comparison -with a Cherokee 6/300 and can't find numbers for the
C182. -Thanks, RT
My experience is consistent with this. I've been keeping track of fuel burn
for the last 2 years since getting the airplane (a '67 but with the O470-U
engine), and my average is 11.3 per tach hour. Most of my cross-country
flights are at relatively high altitudes (10 to 12K) where MP is down to 19
to 20 inches at WOT.
Old July 6th 04, 06:54 PM
Javier Henderson
Jim Weir writes:
What average TAS do you get at, say, 7500' with those settings?
-jav
Old July 6th 04, 07:56 PM
Jim Weir
I usually expect to see 112-115 knots depending on temperature and loading.
Javier Henderson
-Jim Weir writes:
- Depends entirely on how hard you run the engine. I prefer 20" and 2300 RPM
- (makes for a very smooth ride) and get just under 11 gph by the clock.
-What average TAS do you get at, say, 7500' with those settings?
--jav
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Repairing Plastic Instrument Panel Overlay Jeff P Owning 22 January 29th 04 06:42 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
