Wet vac pump question
Old July 12th 04, 11:04 PM
Matt Whiting
Rip wrote:
Agreed. I won't fly hard IFR with a dry pump, and I laugh each time I
throw one of those Parker Hannafin "mandatory" notices in the trash,
unopened. The last wet pump I had overhauled had over 3000 hours on it,
and the overhaul facility changed the bearings, just so they could say
they had done something.
I agree. Dry pumps should be outlawed! :-)
Matt
Old July 12th 04, 11:05 PM
Matt Whiting
JFLEISC wrote:
Any wet pump that uses enough oil to be noticeable is in need of overhaul.
This is what I was wondering. I don't mind getting an overhauled pump if that
will stop it's oil usage, but the feedback on this thread leads me to believe
that many in this group think that 'noticable' quantities of oil out the wet
vac vent tube is normal. Do I have the wrong impression here (I hope)?
Yes, you have the wrong impression. After owning a Skylane for several
years, we had no issue with oil consumption due to the vacuum pump, but
did get enough oil on the belly to require an annual clean-up. However,
it takes very little oil to completely soil the bottom of an airplane.
Probably less than half a cup.
Matt
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
Wet Vacuum Pump smackey Owning 6 February 24th 04 07:03 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
