In my continuing effort to plug all the oil leaks in my Continental 0-300 I
have a final question about wet vacuum pumps. How much oil out the vent is too much? This is a '61 C-172 with the factory standard oil recovery system off the wet vac. About twice as much oil comes out the vacuum vent as out the engine vent. Is that normal and if not what is the fix? Are there seals in the pump that wear out or something? Any info would be appreciated. Jim |
Wet pumps have no seals, per se, and in fact get their lubricating oil
from the accessory pad they are driven from. On many engines this means that the seal is removed from the drive pad. Internally, the pumps have either steel (ARO), or heavy graphite (Pesco, Garwin) vanes that do eventually wear out, but you would tend to see this wear indicated by poor vacuum, rather than extra oil. The typical "output" of these pumps is a lot of air with a fair amount of oil entrained, almost like the spray from an aerosol can. The engine breather vent should have almost no oil at all, and at extremely low pressure (inches of water, rather than PSI). Unfortunately, most air/oil separators don't do a very good job. I've tried 4 or 5 different units, and only the Airwolf did what it was advertised to do. JFLEISC wrote: In my continuing effort to plug all the oil leaks in my Continental 0-300 I have a final question about wet vacuum pumps. How much oil out the vent is too much? This is a '61 C-172 with the factory standard oil recovery system off the wet vac. About twice as much oil comes out the vacuum vent as out the engine vent. Is that normal and if not what is the fix? Are there seals in the pump that wear out or something? Any info would be appreciated. Jim |
is a lot of air with a fair amount of oil entrained, almost like the spray from an aerosol can. I've tried 4 or 5 different units, and only the Airwolf did what it was advertised to do. I was afraid of that. Cheaper to go with a dry pump, I think. Jim |
"JFLEISC" wrote in message ... The typical "output" of these pumps is a lot of air with a fair amount of oil entrained, almost like the spray from an aerosol can. I've tried 4 or 5 different units, and only the Airwolf did what it was advertised to do. I was afraid of that. Cheaper to go with a dry pump, I think. Then you have no experience with a wet pump. Dry pumps are an absolute joke. Owners rave about getting 500 hours out of one. I have a Garwin wet pump on my 182. I give it exactly zero thought. No oil on the belly from the pump either. |
Agreed. I won't fly hard IFR with a dry pump, and I laugh each time I
throw one of those Parker Hannafin "mandatory" notices in the trash, unopened. The last wet pump I had overhauled had over 3000 hours on it, and the overhaul facility changed the bearings, just so they could say they had done something. Javier Henderson wrote: (JFLEISC) writes: The typical "output" of these pumps is a lot of air with a fair amount of oil entrained, almost like the spray from an aerosol can. I've tried 4 or 5 different units, and only the Airwolf did what it was advertised to do. I was afraid of that. Cheaper to go with a dry pump, I think. I think it's more of a lottery. Wet pumps, from what I read, will outlast your engine, whereas dry pumps can last anywhere from .1 to many hundreds of hours. But let's say they last 500 hours on the average, that's four pumps over a 2000 hour TBO engine, reducing the financial advantage of the dry vs. wet pumps. -jav |
That's right, I don't. What I'm interested in right now is cutting down the oil usage. It's not likely this plane will be used for IFR except possibly as a trainer. Jim |
JFLEISC wrote: That's right, I don't. What I'm interested in right now is cutting down the oil usage. It's not likely this plane will be used for IFR except possibly as a trainer. In that case, make sure you keep the old vacuum pump when you replace the pump with a dry unit. You ought to be able to get a fair price for it. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
"JFLEISC" wrote in message ... Then you have no experience with a wet pump. That's right, I don't. What I'm interested in right now is cutting down the oil usage. It's not likely this plane will be used for IFR except possibly as a trainer. Any wet pump that uses enough oil to be noticeable is in need of overhaul. |
This is what I was wondering. I don't mind getting an overhauled pump if that will stop it's oil usage, but the feedback on this thread leads me to believe that many in this group think that 'noticable' quantities of oil out the wet vac vent tube is normal. Do I have the wrong impression here (I hope)? Jim |
| Thread Tools | |
| Display Modes | |
| Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 06:17 PM |
| Windmilling Prop & Vacuum Pump | Matt Young | Instrument Flight Rules | 14 | October 14th 04 09:08 PM |
| Wet Vacuum Pump | smackey | Owning | 6 | February 24th 04 08:03 PM |
| Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 08:09 PM |
| Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 01:35 AM |
