Aztec Flap Tube AD and related Service Bulletin
Old October 31st 04, 12:09 AM
Louis L. Perley III
"Jim Burns" wrote in message
Tires should be 700 x 6 8 plys for the mains and 600 x 6 6 plys for the
nose.... guess how I know?.... The previous owner had the wrong tires on
ours too! 6 ply mains instead of 8 plys and retreads are tough to find.
Don't know much about tires, but what does the number of ply's reference? I
thought it was just some extra layers of rubber (presumably because they're
holding more weight?) I know when I put my C152 back together that it used
6x6.00 6 ply, but hadn't thought much about it. So I guess the question is,
what does the number of ply's measure on an aircraft tire? Why would having
a lower ply count rub on the brakes while a higher number does not? What
year Aztec do/did you own Jim? I thought Kyler Laird was the only other
Aztec owner that regularly posts on the group.
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old October 31st 04, 01:08 AM
Kyler Laird
zatatime writes:
Can anyone point me to a link for Piper Service Bulletin 1051B?
http://www.caa-rs.si/images/pripone/..._MSB_1051B.pdf
http://www.airweb.faa.gov/Regulatory...A?OpenDocument
http://www.tdatacorp.com/03-09-13.HTM
I've got a paper copy around here somewhere. I complied with it
years ago.
--kyler
Old October 31st 04, 04:11 AM
Jim Burns
they're
Exactly.
Why would having
Ours didn't rub, they were just too light of tires for the job. The POH
calls for 8 plys.
What
1966 C model non turbo
We bought it in August.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004
Old October 31st 04, 05:28 AM
zatatime
On Sun, 31 Oct 2004 01:08:04 GMT, Kyler Laird
zatatime writes:
years ago.
--kyler
Thanks! I had the Tdata link and the AD itself. Now I've got a pdf
of the SB and I'm psyched! Thank you for posting this for me.
z
Old October 31st 04, 10:54 PM
G.R. Patterson III
A tire is built up of layers of some sort of fabric (called the cord). A heavy layer
of rubber is then applied over the cord and tread is molded into the rubber. The
number of plys is the number of layers of this fabric. If the layers of fabric are
applied diagonally across the tire, it's called a "bias-ply" tire. If they are
applied perpendicular to the tread, it's called a "radial" tire. Automobile tires are
usually also "belted", which means that additional layers of some sort of material
are laid between the plys in the same direction as the tread.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old November 2nd 04, 08:59 PM
Steven
My 2 cents. We complied with the AD by putting in the new torque tube.
drilled it at the mechanical facility at the FBO and reinstalled it.
Airplane flew wing down and yawed left and right depending on the amount of
flaps. Took it out and examined and reinstalled to no effect.
Obtained an second new torque tube and had a machine shop drill it out and
then installed.
Airplane is in a slip at cruise and yaws with flaps. factory and dealer of
no help.
So.........while practicing approach to landing stalls, the aircraft
suddenly fills with mist. The gear are down and locked. The mist appeared
when lowering flaps. You got it . The torque tube had impinged on the
aileron cable, placed it under tension, caused sideslip in the aircraft and
also caused the aileron cable to saw through the hard aluminum hydraulic
line leading to the flaps.
I do not know that there is a moral to the story. Flying airplanes is
expensive.
"zatatime" wrote in message
zatatime writes:
years ago.
--kyler
z
Old November 4th 04, 04:10 AM
Jim Burns
I'd be extremely interested in a report on your Aztec's annual!!! Thanks!
What year/model?
Old November 4th 04, 05:30 PM
zatatime
On Wed, 3 Nov 2004 20:10:48 -0800, "Jim Burns"
What year/model?
It's an F model. I don't know the year. I don't own it, my friend
does. Since it's getting cold and he keeps it on a grass strip, he's
now thinking of letting it sit until winter passes. He's undecided,
but when it happens I give a report.
z
Old November 5th 04, 08:13 PM
Jeffrey Ross
I'll add my $0.02 as well... last April when my Aztec came due for its
annual ('69 D model) I considered the price of the tube and the labor
involved in pulling to tube to inspect it, and redoing the inspection
ever 500 hrs I decided to be done with it an just replace the tube.
Here's where the fun began...Tube arrives, the mechanic looks closely at
the instructions lays it out as per the instructions and first thing he
notices is if you lined up the bell cranks with the curf cut as
instructed, the flaps will not line up properly. turns out when Piper
built the plane they drilled the hole wrong or cut the curf wrong or
something. Ok, no problem, he rotated the bell crank a few degrees (the
hole needed to be moved about 1/16" of an inch) lines the ends up flush
and drills and reams out the hold.
goes to put the tube in the airplane and finds out that the new tube is
about 1/16" of an inch shorter than the original tube and won't fit in
the bearing blocks, and is now trash.
Second tube comes from the distributer in a FedEx tube, tube arrives
with a 2" hole punched through the bottom and no torque tube.
Third tube comes from the distributer, this time the torque tube is
still inside (barely) and is successfully installed.
In other words remember that these planes were really built one at a
time and the instructions are just a guide but not always definitive.
Jeff
then installed.
no help.
expensive.
zatatime writes:
years ago.
--kyler
z
Old November 6th 04, 12:35 AM
zatatime
On Fri, 05 Nov 2004 15:13:28 -0500, Jeffrey Ross
Jeff
Sheeesh, that was more like a nickel, not just two cents!!! Maybe
even a cuople thousand dollars by the time you add up everything from
your post! Boy do I hope this is not the norm, and that you only
paid for one tube!
Thanks for the input, will be very vigillant when taking care of this.
z
