Aztec Flap Tube AD and related Service Bulletin
Old October 30th 04, 05:33 PM
zatatime
Default Aztec Flap Tube AD and related Service Bulletin
Can anyone point me to a link for Piper Service Bulletin 1051B? It is
what the Aztec falp tube AD refers to for compliance (2003-09-18?). I
have not been able to find it on-line. I'm trying to help someone
figure out the best way to comply, but if I can't read it I can't
understand what is required. Unfortunately, they did not keep the
copy that was mailed to them.
TIA.
z
Old October 30th 04, 06:15 PM
Jim Burns
I've found it almost impossible to find Piper's SB's online.
When we bought our Aztec, the AD had been complied with by replacing the
torque tube. I'll look through our logs in the next day or two to see if
there is a copy of the SB.
If I recall correctly, the AD calls for inspections every 500(?) hours to
check for cracks in the ends of the tubes. I also believe it calls for
replacing the wooden plugs in the ends of the tubes with plastic plugs. It
requires removing the tube from the aircraft no matter if you inspect it or
replace it, however, if you go the replacement route, you can save
time/labor on the removal process with help from a sawzall. I've had quotes
of around $2000 including labor to replace the tube.
There is another local Aztec owner who is also an A&P / AI, I'm sure he'll
have a copy of the SB, it's just tough getting in touch with him.
"zatatime" wrote in message
TIA.
z
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004
Old October 30th 04, 06:52 PM
zatatime
On Sat, 30 Oct 2004 12:15:31 -0500, "Jim Burns"
At least it isn't me....Not sure why they don't just put them on the
website like I've seen others do.
Thanks, but don't go through too much trouble. You pretty much
answered the initial question I had below.
You are correct. I found this in the AD.
It
This is the info I was looking for. I didn't know if you could do the
inspection with the tube in the airplane.
Since you need to pull the tube for inspection it almost makes sense
to just replace it. You'll save some on labor, and never have to do
it again (in theory).
I've had quotes
Ouch! The AD says $480.00 for labor and $572 for parts. I know those
numbers are bogus, but I didn't know they were at a 50% discount!
Thank you very much for the reply. You got me started in the right
direction. If you do find the SB great; if not I'll keep digging.
Thanks again for the help.
z
Old October 30th 04, 06:29 PM
Jim Burns
http://piperchat.com/forum/viewtopic...0759878 e1888
Here's a link to a similar question.
TIA.
z
Old October 30th 04, 08:53 PM
Jim Burns
Found the SB but ours is SB 1051A dated Oct 9 2001, not 1051B It is
instructions for replacement of the torque tube.
TIA.
z
Old October 30th 04, 08:02 PM
Louis L. Perley III
TIA.
z
In the process of going through this on my Aztec as well, they were going to
pull the torque tube yesterday and do the inspection. Depending on what the
replacement torque tube cost, I figured I'd just have them put in the
replacement, which only needs to be checked every 2500 hours, not every 500
with the currently installed one. I'm also told that they replace the wood
caps with plastic since the wood could absorb water and cause corrosion. I
see the various costs quoted in earlier replies, I'll post what my mechanic
tells me, they're almost done with the annual and I should have a squawk
list to go over with them this coming Monday or Tuesday. SO far things are
looking pretty fair, some leaks that need new seals, etc. They did see that
the brakes were rubbing the inside of the tires pretty bad, so I'm not sure
if the previous owner had the wrong tires on or if I'm missing a shim
somewhere. Engine compressions were all in the 70s which was good to hear as
well. I'll post a report on my annual if anyone is interested. This is the
first one for the Aztec since I bought it.
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old October 30th 04, 09:07 PM
Jim Burns
Tires should be 700 x 6 8 plys for the mains and 600 x 6 6 plys for the
nose.... guess how I know?.... The previous owner had the wrong tires on
ours too! 6 ply mains instead of 8 plys and retreads are tough to find.
"Louis L. Perley III" wrote in message
TIA.
z
to
500
mechanic
that
sure
as
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old October 31st 04, 12:09 AM
Louis L. Perley III
"Jim Burns" wrote in message
Don't know much about tires, but what does the number of ply's reference? I
thought it was just some extra layers of rubber (presumably because they're
holding more weight?) I know when I put my C152 back together that it used
6x6.00 6 ply, but hadn't thought much about it. So I guess the question is,
what does the number of ply's measure on an aircraft tire? Why would having
a lower ply count rub on the brakes while a higher number does not? What
year Aztec do/did you own Jim? I thought Kyler Laird was the only other
Aztec owner that regularly posts on the group.
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old October 31st 04, 04:11 AM
Jim Burns
they're
Exactly.
Why would having
Ours didn't rub, they were just too light of tires for the job. The POH
calls for 8 plys.
What
1966 C model non turbo
We bought it in August.
Old October 31st 04, 10:54 PM
G.R. Patterson III
A tire is built up of layers of some sort of fabric (called the cord). A heavy layer
of rubber is then applied over the cord and tread is molded into the rubber. The
number of plys is the number of layers of this fabric. If the layers of fabric are
applied diagonally across the tire, it's called a "bias-ply" tire. If they are
applied perpendicular to the tread, it's called a "radial" tire. Automobile tires are
usually also "belted", which means that additional layers of some sort of material
are laid between the plys in the same direction as the tread.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
