Cold wx starting quirks
Old December 24th 04, 12:14 AM
Roy Smith
"Steven Barnes" wrote:
Our '65 Cherokee seems to like 2 or 3 shots of prime before cranking, with
the primer left out during cranking. When the engine catches, slowly put the
prime in. I've tried variations with the above yielding the least cranking.
We do have Tanis heater and are hangered in a "heated" (read at least above
freezing...) community hanger.
My experience with starting non-injected Cherokees is that you do best
to pump the throttle while cranking instead of worry too much about
priming.
Old December 24th 04, 12:20 AM
zatatime
On Fri, 24 Dec 2004 00:00:47 GMT, "Steven Barnes"
We're hoping to fly the club's 182 to Indiana Christmas day & back the next.
Not sure, as cold as it is here. That 182 is hard starting cold. Yet to find
a good technique for that animal...
WIth the bigger engine you might want to try 4 full shots of prime.
Wait a few seconds, and try to fire her up.
HTH.
z
Old December 24th 04, 01:12 AM
Hankal
My Cessna 172 has the 180 hp
When it is cold here in Florida 40 degrees
I prime once then do my preflight. 3 shots on the throttle and she fires right
up.
Hank
Old December 24th 04, 05:42 AM
nrp
I use 32 degrees F as a preheat-needed criteria on my 172M. Higher if
it has been sitting for several or more days. It might be conservative
but the engine service since new has been outstanding.
Old December 24th 04, 04:05 PM
C Kingsbury
"tony roberts" wrote in message
news:nospam-31132B.20394023122004@shawnews...
Hi Jim
There is one thing about this thread that puzzles me.
you are getting lots of advice on how to start an engine in below zero
temperatures. But nobody has suggested that you preheat the engine.
I would never attempt to start my 0300D engine, below zero, if it wasn't
preheated first. Look up cold starts and engine wear on google for more.
I think the pre-heat is kind of implicit below zero. Still, unless you
really warm the engine up (hard to do in less than an hour) most planes I've
flown are still kinda cranky to start. My 172N has always been pretty good
though- four shots of prime and hit the switch and it will almost always
start after a few blades, pre-heated or not, and it has almost 1900 on the
tach.
Old December 24th 04, 09:26 PM
Jim Rosinski
you really warm the engine up (hard to do in less than an hour) most
planes I've flown are still kinda cranky to start.
Yes, for the purposes of this discussion I assumed preheat is implicit
below about 0 or -5 deg C. Though I don't always have the patience for
an hour or more of preheat time. Thanks to all who posted--I've
learned lots in this cold-starting 101 lesson.
BTW, I've got a great device for preheating. A $20 electric heater
with fan I bought at Kmart that fits beautifully beteween the nose
strut and bottom cowling of my Skyhawk. Nice to find some things in
aviation that can be done cheaply.
Jim Rosinski
Old December 27th 04, 04:58 PM
Andrew Gideon
Could you be more specific about where you place this during use?
Thanks...
- Andrew
Old December 28th 04, 07:18 PM
Jim Rosinski
in aviation that can be done cheaply.
Sure, here are a couple of photos of it:
http://www.burningserver.net/rosinsk...ex.html#HEATER
You can click on each picture to expand it.
Turned out to be just blind luck that it fit beneath the cowling so
well. I actually owned the heater before I bought the airplane.
Jim Rosinski
Old December 28th 04, 08:34 PM
zatatime
On 28 Dec 2004 11:18:30 -0800, "Jim Rosinski"
Jim Rosinski
Thanks for the pics. It's been a long time since I've seen Longmont.
Question: What's with the extra long exhaust pipe on your bird?
z
Engine maintenance under snow during a cold evening ellx Aviation Marketplace 0 December 28th 04 08:24 PM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
Soviet Spy Planes over the West during the Cold War Rusty B Military Aviation 6 February 19th 04 04:53 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
B-52 lands on Cold War enemy's airfield for show Otis Willie Military Aviation 1 August 23rd 03 11:11 PM
