Pit Stop Suggestions
Old October 17th 03, 05:39 AM
Big John
G.R.
My wife always took one of those 'motion sickness' pills before we
flew in GA birds and she never had any problems even on hot days in
rough air. She also takes one now when we fly commercial. Preventative
maintenance.
They also make a patch that works real good for motion sickness.
I always climbed to 6-8K (above the rough air and where it was cool)
if I could, with the wife with me, just to not push the envelope G
Keep the cockpit as cool as you can. May even have to wear sweaters,
etc., but cool air helps with the motion sickness problem.
If your wife continues to get sick, it's going to put a big crimp in
your GA flying (with her) so do everything you can to keep her from
getting air sick (including not flying with her on 'bad' days).
All the best.
Big John
On Thu, 16 Oct 2003 21:10:15 -0400, "G.R. Patterson III"
Jonathan wrote:
If you find any other good restaurants in that neck of the woods, let us
know. Always looking for something new.
Got a briefing Wednesday evening. Forecast for the area was for ceilings 3500'
or more, visibility greater than ten miles, surface winds 17-23 more-or-less in
line with the pertinent runways, winds at altitude of 240 degrees at 25 knots,
and moderate turbulence below 8,000'. Also got a warning that the Yankees game
would close the corridor sometime in the evening.
Got any idea how hard it is to find out when a ball game starts?
We decided to go for it.
The forecast was accurate. I kept the airspeed ten mph over the usual and still
had erratic flickering of the stall warning light. I held best angle of climb
until 1,000 AGL, and then turned north for the corridor. Turbulence was a killer
at that altitude, but I climbed as soon as I got past the Tappan Zee. One new
item I found interesting is the fact that the Air Force now has a Mooney that
circles Manhattan through the East River/Hudson corridors, using "Air Force" as
its call sign. It cut up the East River as we were passing the Intrepid and came
back into the Hudson in front of us over Yonkers. We could hear the pilot as he
announced during his circuit. Yes, it's blue and white.
Once we got past the Zee, I headed for 3,000' and made a beeline for ORE. Things
were looking good. Elisabeth was enjoying the trip, and the light was fantastic.
Visibility was 50 miles or more, and about half the trees had turned. It was
actually pretty smooth up there, and things were looking good. I was pointing
out Torrington when it happened. We hit a couple of mild bumps (nothing like
what we hit in the corridor), and Elisabeth asked for a sic-sack. I asked her if
we needed to land, and, the answer being in the affirmative, I headed for the
nearest airport. That turned out to be Mountain Meadow (22B).
The windsock was straight out and straight across, so I landed in the direction
that put my base leg into the wind. Kept the flaps up, and "crossed the fence"
at 100 mph. I figured that I could get the power on anytime if she started to
weathervane on me. Made a surprisingly gentle touchdown and moved my feet up
to the top of the pedals as soon as we touched. As it turned out, I didn't need
the brakes until the speed dropped to 30 or 40 mph, but it's best to be sure.
As we turned off, I noticed a "cafe" sign.
The FBO is well furnished but appears to be deserted. There *is* a maintenance
hangar with a nice 172 undergoing what appears to be an annual, but nobody was
there either. We used the facilities and waited on Elisabeth's stomach to calm
down. After a while, the A&P returned to work next door, and I suggested we head
over to the grill and get a coke or something to calm Elisabeth's stomach.
As we approach the Landing Zone Cafe, I smelled the unmistakable odor of barBQ.
In Connecticutt? When we got inside and checked the menu, we discovered that the
owner apparently is a displaced Louisianan. We had found what is probably the
only place in New England that serves alligator tail as an appetizer! I should
have taken the hint and bought a southern specialty, but I opted for the clam
chowder. Elisabeth settled for a diet Pepsi. The chowder was ok - thin, but lots
of clams. We got a nice t-shirt out of the deal, too.
Back at the FBO, we patted the mechanic's dog, and launched back into the wind.
I decided to take the long way around the class-B to minimize the turbulence,
but it did little good. There were a few patches of near-solid yellows and reds
close to Yorktown, but Elisabeth was not in the best mood to appreciate them.
The up/down-drafts in the Caldwell/Morristown area made it difficult to stay
between 2700' (the class D top) and 3000' (the class B floor), but once I got
past MMU and turned south, things were a bit better. The sound of dry heaves
from the right seat is also a distraction they don't usually throw at you on
check rides.
Winds gusting from 17 to 23 knots and varying from 240 to 280 made landing on
24 an interesting proposal, but we got down intact. Elisabeth collapsed on one
of the couches at the FBO while I put the Maule to bed.
Due to the severity and suddenness of her reaction, we think Elisabeth's coming
down with a bug of some sort. A little hot&sour soup at the local Chinese place
has reduced the symptoms, and an early bedtime is in order for her.
Looks like there's still lots of green in that area though. We might try it
again in a week or two. Maybe I'll try the alligator tail this time!
George Patterson
To a pilot, altitude is like money - it is possible that having too much
could prove embarassing, but having too little is always fatal.
Old October 17th 03, 06:13 AM
Big John
Wrong wording. Should have said "bad flying days"
Big John
On Thu, 16 Oct 2003 23:39:03 -0500, Big John
G.R.
maintenance.
All the best.
Big John
check rides.
George Patterson
Old October 18th 03, 02:41 AM
G.R. Patterson III
maintenance.
Elisabeth usually does this. Since I told her the forecast included moderate
turbulence below 8,000', and she knows what that is, I assumed that she took
her usual dose. I was wrong. Add that to my pre-pre-pre-flight checklist -
"Make sure E. took her pill".
That's what I do on long trips where feasible. The Hudson corridor, however,
has a cap of 1,100', which is the floor of the NY class-B. Once past that, we
were dealing with a cloud deck at an estimated 4,000'. Also keep in mind that
the purpose of the trip was to view the leaves, which view is less dramatic
at 6 grand than otherwise.
Did that. I'd bet that it was a big help at first.
Yep, it does that a bit, but we've been flying together about 9 years now. These
days, however, we have to plan flights ahead ('cause of our schedules) and take
our chances with the weather. Just *have* to remember the Dramamine.
George Patterson
Old October 18th 03, 04:50 AM
Big John
George
Looks like you 'been there done that'. No use of me preaching to the
choir G
Dramamine is also what my wife uses. Tolerates it well.
Went to school up the Hudson. Also stationed at Stewart AFB, Newburgh,
so know the area (way prior to 9/11 of course)
Lots of years (10) in NE US and fall colors are beautiful up there.
Here in TX the prairie just turns brown until next spring G
Fly safe and enjoy the fall (before the winter Wx comes).
Big John
On Fri, 17 Oct 2003 21:41:41 -0400, "G.R. Patterson III"
maintenance.
George Patterson
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Rabbi Urges Pig Fat on Buses to Stop Bombers Mike Marron Military Aviation 11 February 20th 04 11:37 PM
Need suggestions for clean butt splice for electrical wires. Bart D. Hull Home Built 9 January 30th 04 04:28 AM
Plan Suggestions Bill A. Home Built 2 January 9th 04 07:27 AM
