Need suggestions for clean butt splice for electrical wires.
Old January 29th 04, 09:01 AM
Bart D. Hull
Default Need suggestions for clean butt splice for electrical wires.
I'm working on the firewall forward for my homebuilt.
I need to extend various wires to make it to their respective destinations.
(14 to 26 gauge wires.)
Any way to have a nice clean butt joint? I don't like the crimp butt joints
or twisting the wires together with the accompanying monster bulge.
What have y'all used for a central ground or central power point? I'm building
a composite so I can't use the airframe as a convenient ground.
Suggestions and/or pictures are appreciated.
Thanks
Bart D. Hull
Tempe, Arizona
Check
http://www.inficad.com/~bdhull/engine.html
for my Subaru Engine Conversion
Check http://www.inficad.com/~bdhull/fuselage.html
for Tango II I'm building.
Old January 29th 04, 01:23 PM
Fred in Florida
"Bart D. Hull" wrote in message
destinations.
joints
building
Bart --
I'm using these from B&C on my composite project. Look about 1/3 to 1/2 way
down the page. Good luck.
http://www.bandc.biz/cgi-bin/ez-cata....cgi?26X358218
Fred in Florida
Old January 29th 04, 04:42 PM
Tarver Engineering
destinations.
joints
building
Use a terminal block, or a Burndy block.
Do not solder the wires.
Old January 29th 04, 06:07 PM
Nathan Young
On Thu, 29 Jan 2004 07:42:05 -0800, "Tarver Engineering"
destinations.
joints
building
I've noticed this - why does aviation not solder wires? Is it a
reliability thing? Ie the solder joint would fracture after enough
vibration and time?
With my A&Ps guidance, I've done a bit of wiring under the panel of my
plane. One thing is for sure - I wouldn't want to be soldering under
there - you'd get a facefull of solder droplets. OUCH!
-Nathan
Old January 29th 04, 06:20 PM
Tarver Engineering
"Nathan Young" wrote in message
destinations.
joints
building
vibration and time?
Solder melts and shorts other things out.
The smell of bunig skin is usually your first indication; followed by
cutting your head up trying to escape.
Old January 29th 04, 07:02 PM
Mike Patterson
On Thu, 29 Jan 2004 17:07:17 GMT, Nathan Young
SNIP
vibration and time?
An A&P friend told me that the vibration/fracture answer is the
reason.
I helped him build a TEAM Minimax and every wire on that thing was
mechanically connected and strain-relieved at both ends somehow.
It amazed me how much time we spent doing all that to his
satisfaction, but I sure learned a lot.
-Nathan
Mike Patterson
Please remove the spamtrap to email me.
Old January 30th 04, 12:10 AM
Roger Halstead
destinations.
joints
building
vibration and time?
Yes, for the short answer.
As a demonstration, take a piece of aviation wire and cut it in two.
Crimp a spade lug on the end of each piece. On one, solder the wire in
the connector.
Now, bend the wire back and forth.
The one soldered into the connector should break far sooner than the
one that is only crimped.
www.rogerhalstead.com
-Nathan
Old January 30th 04, 12:54 AM
Rob Cherney
On Thu, 29 Jan 2004 01:01:44 -0700, "Bart D. Hull"
It's not a cheap solution, but this is a solder sleeve that meets your
requirements. As you can see from other posts, the conventional
wisdom is to avoid solder splicing, but this particular product
includes a controlled amount of solder to prevent wicking beyond the
sleeve. Be sure to use the part recommended for the application.
http://www.raychem.com/US/datasheets...8/8-6_8-11.pdf
Rob-
Robert Cherney e-mail: rcherney(at)comcast(dot)net
Old January 30th 04, 01:05 AM
Tarver Engineering
"Roger Halstead" wrote in message
snip
Some people would just use a backshell.
Solder is OK as long as there is no way for it to short out other equipment.
BCAG uses soldered connector contacts.
Old January 30th 04, 05:28 AM
B2431
Date: 1/29/2004 5:10 PM Central Standard Time
Message-id:
destinations.
joints
building
vibration and time?
the connector.
A properly supported wire won't have that problem. Look at cannon plugs. I have
seen many cases in homebuilts where the builder has used far too little
support.
Having said that crimping makes for an easier and quicker assembly. In most
cases there's no reason not to crimp. If you crimp a splice or terminal in an
environment where corrosion is to be expected wrap it in silicone tape, use
heat shrink tubing or the like to prevent contamination of the crimp.
Dan, U,S. Air Force, retired
