AR 4201 low volume on receiving side
Old June 23rd 12, 01:40 AM posted to rec.aviation.soaring
Wheaton
Default AR 4201 low volume on receiving side
On Wednesday, June 20, 2012 9:08:11 AM UTC-6, Alexander Swagemakers wrote:
I have purchased a used Becker AR 4201 and installed it in my glider. Reception is fine. On transmission the signal volume is very low on the receiving side. Even though the voice is clear, it is hardly understandable because of the low volume. I tried making some changes to the configuration to no avail (especially settings concerning the microphone).
Any ideas on what the problem might be? Has anybody experienced similar behavior before?
I had the identical problem two years ago. Sent it to Becker repair in Florida and they replaced a board. Now it works fine. $300+ Joe
HP310 and hx4705 - side by side, first impression Tuno Soaring 8 February 23rd 09 07:30 PM
HP310 and hx4705 - side by side, first impression Darryl Ramm Soaring 0 February 22nd 09 02:42 AM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
