I have 3 mouse antennas attached to my glareshield using nylon velcro
material. (Logger, backup loggger, Flarm) The break away feature is not relevant as my panel stays with the glider... All work well, 11cm separation to Flarm antenna seems to be fine. Bruce On 2012/07/23 2:11 AM, kirk.stant wrote: I'm thinking of mounting a couple of "mouse" GPS antennas on the inside of my fiberglass LS6 panel cover using Dual-Lock on the TOP of the GPS antenna. Reason is to have more real estate to place the antennas, and still provide a "break-away" function if I have to jettison the canopy (and cover, which goes with it). Any opinions about any effect the plastic Dual-Lock would have on GPS reception? My gut feeling is "no effect", but I claim no deep knowledge of the electromagnetic spectrum (other than how to run a no-lock intercept using an APQ-120...). Comments? Kirk 66 -- Bruce Greeff T59D #1771 |
Thanks for all the replies - got the info I needed.
I've been using the external/high temp 3M Dual Lock for a while (PCAS on top of glareshield, SPOT in baggage area) and that stuff is awesome - no problems with it getting loose or the sticky tape releasing. Highly recommended! Kirk 66 |
Pegasus panel cover | Charles Kotila | Soaring | 0 | June 30th 12 11:07 PM |
PowerFlarm mounting question, and an idea for mounting devices | brianDG303[_2_] | Soaring | 2 | October 23rd 11 06:51 PM |
PIREP Needed - Aircraft Door Seals Instrument Panel cover | Mike Spera | Owning | 2 | June 24th 06 05:02 PM |
Antennas | Terry | Home Built | 3 | April 24th 05 06:42 PM |
Antennas | Terry | Home Built | 3 | April 22nd 05 03:14 AM |
