14CFR Part 1
Sec 1.1 Flight time means: (1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or Ok, so I'm at Dulles. I start up, release the brakes, and start the timer. Start taxiing (it takes forever at Dulles), do my runup, am sixteenth behind a row of jumbos, have to hold a while for IFR release, andforty minutes later the tower tells me position and hold. (not too far off for some flights!). Cleared for takeoff, I accelerate to flying speed, but something isn't right, so I abort the takeoff and taxi back to the ramp and shut down. It's been an hour and eighteen minutes. Do you log it as 1.3? Do you log it if you actually managed to get three feet in the air for twelve seconds before aborting the takeoff and landing again on the mile of runway remaining? Jose -- (for Email, make the obvious changes in my address) |
![]() "Ron Rosenfeld" wrote in message ... On Sun, 21 Dec 2003 11:00:59 -0800, A Lieberman wrote: I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. You didn't look at the beginning: 14CFR Part 1 Sec 1.1 Flight time means: (1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or (2) For a glider without self-launch capability, pilot time that commences when the glider is towed for the purpose of flight and ends when the glider comes to rest after landing. For most people with a Hobbs, that could be an extra half hour, from master switch "ON", to shutdown. I wonder: does ANYONE does it that way? |
![]() Tom Sixkiller wrote: For most people with a Hobbs, that could be an extra half hour, from master switch "ON", to shutdown. I wonder: does ANYONE does it that way? I do. My Hobbs does not have an oil pressure switch, it starts counting from Master On. A typical roundtrip breakfast flight will have .2 taxi time to the runway. |
![]() "A Lieberman" wrote in message ... Tom Sixkiller wrote: At what point can one start recording _Flight Time_? Engine start? First master switch? I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. Flight time is defined in part 1. |
![]() "A Lieberman" wrote in message ... Tom Sixkiller wrote: At what point can one start recording _Flight Time_? Engine start? First master switch? I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. That's about what I've always used; from engine startup. |
![]() "Tom Sixkiller" wrote in message ... At what point can one start recording _Flight Time_? Engine start? First master switch? Since we are talking pilot time (we have bounced back and forth here), the rules say: elapsed time form the time the aircraft first moves under its own power for the purpose of flight until the time it comes to rest at its . Since my plane rears forward a little bit at engine start, and I don't tend to run it for very long when I finally get fully parked, the ENGINE RUNNING (hobbs) time is usually pretty danged close to the definition. |
![]() "Ron Natalie" wrote in message m... "Tom Sixkiller" wrote in message ... At what point can one start recording _Flight Time_? Engine start? First master switch? Since we are talking pilot time (we have bounced back and forth here), the rules say: elapsed time form the time the aircraft first moves under its own power for the purpose of flight until the time it comes to rest at its . Since my plane rears forward a little bit at engine start, and I don't tend to run it for very long when I finally get fully parked, the ENGINE RUNNING (hobbs) time is usually pretty danged close to the definition. I remember, several years back, a lot of pilots would do their engine start, and THEN do their ATIS, CD, Ground... Too expensive to do it that way except for the corporate jocks, big iron... |
I have always used either my watch (no hobbs) or if equipped .. the hobbs...
one should only apply the 1.3factor to straight tach time. BT "Jay Honeck" wrote in message news:7oiFb.618964$Fm2.558042@attbi_s04... With built-in flight timers becoming the norm in virtually all new avionics (heck, even the new transponder I'm getting has one), just wondering if folks are migrating away from using hobbs/tach time to record their flight time? And if you *are* using the flight timer, have you stopped using the old archaic "1.3 hours" method of recording flight time? Anyone using actual hours and minutes in their logbook instead? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article 7oiFb.618964$Fm2.558042@attbi_s04, "Jay Honeck"
wrote: With built-in flight timers becoming the norm in virtually all new avionics (heck, even the new transponder I'm getting has one), just wondering if folks are migrating away from using hobbs/tach time to record their flight time? And if you *are* using the flight timer, have you stopped using the old archaic "1.3 hours" method of recording flight time? Anyone using actual hours and minutes in their logbook instead? I record engine start to engine stop (excluding the taxi time rom the pump back to my hangar). -- Bob Noel |
With built-in flight timers becoming the norm in virtually all new avionics (heck, even the new transponder I'm getting has one), just wondering if folks are migrating away from using hobbs/tach time to record their flight time? I can't think of any reason to stop using the hobbs. I don't have to leave the avionics on after the flight to check the GPS time, the hobbs is always right there as I'm closing the door. I also use my hobbs to track the time I've spend on each tank (even though I have an EDM fuel flow computer). The hobbs seems like a perfect, simple device. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
