Temperature Probe for Dell Streak
Old April 19th 13, 01:32 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Temperature Probe for Dell Streak - Question for Eric Greenwell
On 4/18/2013 7:06 AM, Dan Marotta wrote:
Those look great except for the fixed probe. Did you take yours apart
and remote the probe to the vent system? The price is cheap enough that
I could afford to risk destroying one (or two)...
On 4/17/2013 4:00 PM, Dan Marotta wrote:
Hi Eric,
Please tell me exactly what thermometer you got and where. I can't find
anything suitable on the internet or at the local hardware store. Maybe
I'm just not asking the right questions.
I replied privately with a picture, but here are the links:
I bought it on amazon.com. Search for "digital food thermometer". This
one seems to do the same things, but looks a little different:
http://www.amazon.com/Taylor-9842-Co...ref=pd_sim_k_3
The on/off button turns it on and off; also, it will shut off
automatically in a minute or so. That's fine with me. I believe, but
I'm not positive, that this one has a real on/off button, if you don't
want it to turn off automatically.
http://tinyurl.com/cqvnnp3
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
No, I just stuck in through a hole in vent duct near the eyeball vent,
and it reads the OAT within a degree F.
email me)
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old April 19th 13, 02:01 AM posted to rec.aviation.soaring
Dan Marotta
Nah... I use a K6BT so I'm outta luck there. I'm gonna buy one of those
digital meat thermometers, take it apart, and try to mount the sensor
remotely. If I fail it's only about 10 bucks.
"Kimmo Hytoenen" wrote in message
If you use IOIO card to connect your CAI to Streak, you cab build
temperature measurement that connects the inputs of the IOIO.
Cost is low, soldering needed. We (soartronic) will try to find time
to make explanation how to do it.
Old April 19th 13, 02:51 AM posted to rec.aviation.soaring
Bob Faris
On Apr 18, 7:01*pm, "Dan Marotta" wrote:
Nah... *I use a K6BT so I'm outta luck there. *I'm gonna buy one of those
remotely. *If I fail it's only about 10 bucks.
Here's another option:
http://www.digitalthermometers.net/m...dp300pp.asp x
Bob Faris
Old April 19th 13, 05:56 PM posted to rec.aviation.soaring
soartech[_2_]
No need to take apart thermometers. Every Walmart and hardware store
carries small digital
thermometers that have an "outside" wired sensor for less than $10.
Put the sensor in your vent
and stick the little display anywhere. It never turns off either.
To get temperature into your Dell Streak use the IOIO box and a serial
output temp sensor.
Something like this:
http://www.microchip.com/paramcharts...branchID=90003
Old April 20th 13, 02:56 AM posted to rec.aviation.soaring
Dan Marotta
That.s perfect, Bob!
I'd already ordered another unit that I'll have to modify for my needs and,
if I fail, I'll get the one you suggested. My only concern is that the
wires might be too short, but I can fix that easily.
"Bob Faris" wrote in message
message
Bob Faris
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more Evan Ludeman[_4_] Soaring 2 December 31st 12 12:14 AM
Dell Streak 5 available soartech[_2_] Soaring 0 November 14th 12 05:44 PM
Short review of the Dell Streak with XCSoar Max Kellermann Soaring 6 February 9th 11 04:22 PM
Location for temperature probe in ASG 29? Tuno Soaring 2 March 28th 08 06:32 AM
Outside air temperature probe dlevy Owning 9 November 7th 06 05:14 PM
