PowerFlarm Declaration
Old June 7th 13, 08:56 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Default PowerFlarm Declaration
Is there a way to declare to a portable PowerFlarm or do you just use written declaration with the IGC file?
Old June 7th 13, 09:19 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Modify your flarmcfg.txt file. Use free flarm config tool software -
http://www.segelflug-software.de/prod_flarmcfgtool.html. Change the
waypoint file using the file of your country (most are in the
software). Select your task waypoints. Push button to make a
flarmcfg.txt file on your microSD card. Insert microSD card into your
portable. Power up.
If your desired waypoints aren't in the country waypoint file, you may
have to edit the waypoint.fln file.
You may be able to declare directly from a PDA. I am able to create
declarations in XC Soar, and send to my PowerFLARM Core/Brick via an
IOIO card and android phone.
Either way gets a valid IGC declaration into my PowerFLARM. Easiest/
cheapest is via microSD or USB flarmcfg.txt file.
Old June 7th 13, 09:24 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
I believe the European Flarm is different then the US PowerFlarm. Does this work with US version.
portable. Power up.
Old June 7th 13, 09:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Modify your flarmcfg.txt file. *Use free flarm config tool software -
portable. Power up.
Either way gets a valid IGC declaration into my PowerFLARM. *Easiest/
It does in Canada with a Brick - same as US. FLARM file is the same
no matter what hardware it is on.
Old June 7th 13, 09:41 PM posted to rec.aviation.soaring
Dan Daly[_2_]
portable. Power up.
It does in Canada with a Brick - same as US. *FLARM file is the same
# declaration
//Task declaration
$PFLAC,S,NEWTASK,12may13
$PFLAC,S,ADDWP,4053033N,07754433W,Ridge So
$PFLAC,S,ADDWP,4102167N,07735883W,Howard D
$PFLAC,S,ADDWP,4039767N,07813100W,Tyrone Gp
$PFLAC,S,ADDWP,4108033N,07721233W,Lock Hav
$PFLAC,S,ADDWP,3941733N,07845850W,Quarry3
Here's a 500 I declared from Ridge Soaring Gliderport using it from my
flarmconfig.txt file using the software.
Old June 7th 13, 11:22 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Thanks Dan, I'll give it a try.
portable. Power up.
# declaration
//Task declaration
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 06:56 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
PowerFlarm flight declaration Bob 7U Soaring 2 November 16th 10 03:58 PM
NEW Declaration Requirements Judy Ruprecht Soaring 19 October 1st 09 03:46 PM
Electronic declaration tango4 Soaring 12 June 24th 04 09:34 AM
