Electronic declaration
Old June 22nd 04, 05:16 AM
tango4
Default Electronic declaration
2 questions folks.
1 - How does one declared a free distance task electronically?
Declare takeoff and (possible) landing points only?
2 - If a declaration of any task is made electronically and the logger is
sealed in the glider does the declaration still need to be refreshed every
day to include the date of the flight or will one declaration cover several
days of flying?
I'm thinking of a situation where you are away from OO's for a period.
TIA
Ian
Old June 22nd 04, 06:36 AM
Eric Greenwell
tango4 wrote:
2 questions folks.
No declaration required: tow release would be the start; landing the
finish. A motorglider is a bit different.
days of flying?
THe declaration has to be made before you take off, and there is no time
limit on how long before. I often have a declaration that is a month or
more old.
You still need witnesses at the start and finish, though in the case of
a distance flight, the witnesses don't necessarily have to see the landing.
Eric Greenwell
Washington State
USA
Old June 22nd 04, 07:40 AM
Ramy Yanetz
I'll add couple more questions:
1 - How does one electronically declare a task with post declared start and
finish (such as 1000km diploma where the start and finish do not need to be
declared) without the logger automatically assign the first and last
turnpoints as start/finish?
2 - Can a flight considered valid for FAI badges or records if the power is
temporarily interrupted (which results in 2 log files)?
Ramy Yanetz
tango4 wrote:
2 questions folks.
is
every
several
days of flying?
more old.
landing.
Eric Greenwell
Washington State
USA
Old June 22nd 04, 06:19 PM
tango4
"Ramy Yanetz" wrote in message
m...
and
be
Can you get a 1000km diploma with a free distance flight? It was my
understanding that Klaus Ohlman has not got a 2000 km diploma because his
flights of 3000 km and more were free distance rather than pre declared.
In 2.1.4 The sporting code states that the badges are awarded for 'distance
flights' of 1000km or more.
A distance flight for badges or for badges and records is defined and must
be declared
is
Depends! If the finish of 1 logfile and the start of the next are less than
60 seconds apart then I think you can. Not sure beyond that.
Several years ago the IGC rehashed the sporting code section 3 to simplify
it but if you ask me it's still confusing and I consider myself to be at
least of average intelligence.
Ian
Ramy Yanetz
tango4 wrote:
2 questions folks.
is
every
several
days of flying?
more old.
landing.
Eric Greenwell
Washington State
USA
Old June 22nd 04, 09:56 PM
Tim Newport-Peace
X-no-archive: yes
In article , tango4
writes
is
Flight Recorders that comply with the latest specification will continue
with the recording without creating a new file after a power break of up
to about 5 minutes. I remember that Volkslogger does not do this however
many others do.
It would seem logical that five minutes can elapse between the end of
one file and the start of the next. The figure 60 seconds is the maximum
setting between fixes in normal operation, but does not mean that a
break in power exceeding this but less than five minutes will invalidate
the flight.
Tim Newport-Peace
"Indecision is the Key to Flexibility."
Old June 23rd 04, 01:06 AM
Eric Greenwell
be declared
According to this, a straight distance course is allowed:
1.4.5 Distance performance for badges only
a. STRAIGHT DISTANCE
A flight from a START POINT to a FINISH POINT with no TURN POINTS. No
DECLARATION is required unless a START POINT other than the RELEASE
POINT is used or the FINISH POINT is also to be a GOAL.
Eric Greenwell
Washington State
USA
Old June 23rd 04, 01:15 AM
Eric Greenwell
declared
No action is required for courses that do not need a declaration. The
start and finish are not "post-declared" but are the release and landing.
The logger doesn't automatically do anything - it just lists the
turnpoints. You might see some kind of assignment for takeoff and
landing on flight display programs like SeeYou, but that is not the
logger. What logger are you using?
Eric Greenwell
Washington State
USA
Old June 23rd 04, 05:43 AM
Ramy Yanetz
and
be
declared
1000km diploma require declaration of turnpoints only. Start and finish can
indeed be the release and landing.
I am using winpilot declaration for volkslogger. It automatically assigns
the first turnpoint as start point and the last as finish, so the declared
task distance is much shorter. Will the release/landing still be considered
as start/finish even if other turnpoints are declared as such?
Ramy
Old June 23rd 04, 07:54 AM
K.P. Termaat
"Ramy Yanetz" schreef in bericht m...
Snip...
1.4.5.b. says "This course must be declared" not "The turnpoints must be declared".
Karel, NL
Old June 23rd 04, 07:47 PM
Eric Greenwell
and
be
declared
We've exceeded my knowledge of specific logger declaration methods, as
I'm most familiar with the Cambridge units. Is it possible to use
Volkslogger software to declare things differently? Or is there some way
to select "release" and "landing" as part of the declaration, so the
turnpoints don't get used for start/finish? There must be a way, since
release and landing are common features in badge and record flights. As
a workaround, you could use a paper declaration, but that is not very
satisfactory.
Eric Greenwell
Washington State
USA
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA Otis Willie Naval Aviation 0 April 30th 04 09:45 PM
Stars and Stripes Offers Free Electronic Newspaper, By Sgt. 1st Class Doug Sample, USA Otis Willie Military Aviation 0 April 30th 04 09:45 PM
Future Electronic Attack Aircraft Mike P. Military Aviation 1 April 22nd 04 01:30 AM
Electronic Ignition Andre Home Built 1 September 5th 03 06:15 PM
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
