Take a look at our club operations manual for more on how we operate our
plane: http://baldeagleflyingclub.org/Manual.htm There is a section on running it lean of peak. Not all engines will do this, even within the same make and model. Ours won't do it in all weather conditions. When it works, its great though. -- Roger Long |
On Wed, 31 Mar 2004 10:25:02 GMT, "Roger Long"
om wrote: This is the procedure we use on our O-320 and have had noticeably smoother and quicker starts since we started it: RPM - 1200 Lean for maximum RPM rise. (Don't worry, no amount of leaning will hurt the engine at this low power) Run 20 seconds Throttle - Quickly to Idle Mixture - Idle Cut Off Switches - OFF Leaning for all ground operations is vital to keep the mags clear on this engine. On startup and after exiting the active runway, set RPM to 1000 and lean slowly for maximum RPM rise. This will often be about 100. Lean slightly past until RPM just starts to fall. If the engine runs a hair rough, that's OK. It will be lean enough that it will start to stumble and quit if you try to run it faster than about 1300. This means you can't accidentally take off with it leaned. Since we started doing this, I have only had to clear a mag a couple of times in two years. Roger Long Roger, when you say "clear a mag" do you mean clearing plugs? Because it isn't the mag that fouls, is it? Isn't it the plugs? Thanks, Corky Scott |
Yes, it is the plugs. Since you switch a mag off people often say clearing
a mag even though it's sort of like saying "digging a shovel". Mags do foul for very different reasons but the only way to clear them is with a wallet. -- Roger Long Roger, when you say "clear a mag" do you mean clearing plugs? Because it isn't the mag that fouls, is it? Isn't it the plugs? Thanks, Corky Scott |
Lotsa "depends"... One of the benefits of owning a plane, or flying the
same one most of the time, is that you get to know the idiosyncrasies... On mine, from experience I know the proper rpm for mixture cutoff that gives the smoothest shutdown, and 99 times out of a 100 results in both props stopping at the same angle... Just a game I play for my own satisfaction... There is also the method of going to 1800-2000 rpm, pulling the mixture as lean as it will go without shutting down, wait 10-15 seconds, then gently close the throttle to idle, wait until the engine slows, then fully cut the mixture... This helps to clear lead fouling off the plugs... denny "Lisa" wrote in message Which is best? |
"Dennis O'Connor" wrote in message ...
Lotsa "depends"... One of the benefits of owning a plane, or flying the same one most of the time, is that you get to know the idiosyncrasies... On mine, from experience I know the proper rpm for mixture cutoff that gives the smoothest shutdown, and 99 times out of a 100 results in both props stopping at the same angle... Just a game I play for my own satisfaction... There is also the method of going to 1800-2000 rpm, pulling the mixture as lean as it will go without shutting down, wait 10-15 seconds, then gently close the throttle to idle, wait until the engine slows, then fully cut the mixture... This helps to clear lead fouling off the plugs... denny We run an O-360 with an Ellison TBI... the plugs tend to foul very quickly, even if the engine is leaned during taxi. Therefore, our shutdown procedure is to run up to about 1300 rpm and pull the mixture out to right about peak. We let it run like that for 20-30 seconds, then throttle back to about 800. Mixture is chopped to cutoff, then we push the throttle up. As soon as it starts to speed up, we cut the ignition off. This process results in a clean start for next time, and the least amount of shaking we've managed to accomplish without the engine deciding to spin backwards for a few revs. |
"Lisa" wrote in message ...
Perhaps this doesn't matter much for a non-turbocharged engine, but an instructor says that it is best to idle the engine at 1,000 RPM for a few moments before Mixtu Idle Cut-Off at that RPM to shut down. The POH says throttle full aft, then mixture cut-off to shut down. I run at 1100 RPM just before shutdown, set the throttle lock, and then pull the mixture back. This way, when I restart on a cold day, I know that the engine will fire and idle nicely at 700 RPM without overrevving or conking out. This minimizes engine wear on startup. Not sure I agree with posts (from Lycoming recommendation) which suggest high RPM. Too much risk of damage to the prop. |
Yes, you will have more prop wear. However, if you have an O-320 H2AD, the
most vulnerable thing in the engine are the camshaft and lifters. Idling below 1000 is hard on them because of reduced oil splash and higher metal pressures. Better a $500 prop overhaul than the $8000 camshaft replacement we just went through. -- Roger Long Tony Cox wrote in message ink.net... "Lisa" wrote in message ... Perhaps this doesn't matter much for a non-turbocharged engine, but an instructor says that it is best to idle the engine at 1,000 RPM for a few moments before Mixtu Idle Cut-Off at that RPM to shut down. The POH says throttle full aft, then mixture cut-off to shut down. I run at 1100 RPM just before shutdown, set the throttle lock, and then pull the mixture back. This way, when I restart on a cold day, I know that the engine will fire and idle nicely at 700 RPM without overrevving or conking out. This minimizes engine wear on startup. Not sure I agree with posts (from Lycoming recommendation) which suggest high RPM. Too much risk of damage to the prop. |
Lisa wrote in message ...
Perhaps this doesn't matter much for a non-turbocharged engine, but an instructor says that it is best to idle the engine at 1,000 RPM for a few moments before Mixtu Idle Cut-Off at that RPM to shut down. The POH says throttle full aft, then mixture cut-off to shut down. Which is best? The idle at 1,000 RPM sure helps in my IO-360 engine. My engine hot starts great, and cold starts great, but is very hard to warm start. Idling at 1,000 RPM (or 1,200 RPM) for a couple minutes seems to make a huge difference. -Robert |
When we used to run Cessna 150s, we often found them hard to start.
Then we noticed that just after a flight, or lengthy runup before inspection, that oil would dribble out of the bottom plug holes when we pulled the plugs. These engines tend to foul the bottom plugs at idle for some reason, and we instituted a 1700 RPM runup prior to shutdown to clear them. No more hard starts or fouled plugs. We have few fouling problems with the Lycs, other than with too much circuit work. Dan |
My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 05:02 PM |
Starting Engine Question (O-320, Warrior) | Lisa | Piloting | 13 | April 1st 04 06:45 AM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
engine overhaul & autopilot question | CriticalMass | Owning | 8 | February 13th 04 06:11 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
