Portable XM Radio receiver in the cockpit?
Old September 2nd 04, 02:12 AM
Mark Manes
The reason for the loss of audio is that there is a impedance mismatch.
Freemar sells an impdance matcher that will plug into the Roadie and the Aux
audio input in the audio panel (Garmin 340 in my case). I usually set the
Roadie audio output to 2 or 3 and have plenty of XM audio.
http://www.fremarllc.com/accessories/index.html
Aeromedix also sells a 28v to 6v cig plug adapter that will fit the Roadie.
http://www.aeromedix.com/index.php?_...3893f0567f32d9
The one from Radio Shack is cheaper. The Radio Shace catgalogue shows the
adapter to be 12 to 24v input and 6v output. It works just fine. I tried
both.
Mark Manes
N28409
WC5I
"Peter R." wrote in message
Jim Weir wrote:
Somebody said that they had used the cigarette lighter for power. Just
remember
that the little bugger needs SIX volts and that the regulator is in the
ciggie
lighter plug. Connect the Roadie directly to 12 volts and you have an
expensive
lump of silicon in your hand.
Whoa. Thank you, Jim, for the warning.
I powered it from a version of the GPS adapter panel, put a 6 volt
regulator on
the backside of the panel, the GPS antenna connector on the same panel,
and it
looks like a factory install.
As someone who only has the basics of electronic knowledge, I am
confused. The cigarette lighter plug shipped with the Roadie is not
designed to reduce the voltage to the correct six volts?
If not, what parts would I need (the GPS is an IFR-certified panel
mounted model) to power the Roadie in the aircraft? Is there an off-
the-shelf solution?
Peter
Old September 2nd 04, 12:57 PM
john smith
both.
That was my first thought. I was suprised Jim Weir didn't mention it.
Old September 2nd 04, 02:33 PM
Michelle P
Peter,
Works great! I have been doing it for several years. It is nice to be
able to get good Music all the way to Key West.
I put my antenna in the back and the receiver under my seat but I have a
fabric airplane. I have an old Sony receiver.
Michelle
Peter R. wrote:
I have made the jump to satellite radio for my car, choosing XM Radio as
my provider. Wow, am I in love now that I am free of the canned format
of commercial radio!
I was wondering if anyone has taken the portable version of the XM radio
receiver, in my case called the Delphi Roadie or Roadie 2, and used it
in the cockpit?
It seems like it would be pretty straight forward to do, placing the
antenna inside the cockpit forward of the glare shield, then interfacing
the radio to the AUX input of the audio panel. Just wondering about
others' experiences.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old September 4th 04, 03:46 AM
Peter R.
Thanks, Michelle!
Peter
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
Portable GPS: receiver and laptop/palm or selft contained unit picopirate Owning 11 May 16th 04 11:37 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
