Anyone else here ever experience one? How did yours happen? Fly long enough and something will hit the fan. I was taxiing out to the runway after a torrential downpour flooded the ramp. I taxiied on the high spots at minimum power just in case. At minimum power (flat pitch) the blade tips are actually causing reverse thrust because of the twist in the blades. I thought I had missed the standing water and the plane flew normally for the rest of the day (10 legs). During a maintenance inspection that evening, I put a protractor on the blades and they were indeed twisted more than the factory meant for them to be. I had caught the blade tips in the water and the reverse angle of the blade tips caused the blades to twist ever so slightly. The prop overhaul with 4 new blades and an engine gearbox teardown came to around $24k not including loss of use and the mechanics' salaries. The prop shop mentioned that if I had not exercised caution by using minimum power, the blade tips would have been nearly flat and wouldn't have twisted the blades. I've been careful to be uncareful ever since. D. |
I had two prop strikes on a twin when the nose gear wouldn't come down and I
had to land on the mains. Will never forget the tick-tick-tick of the prop tips on the concrete. Or the short rollout. Or the jaunty angle when deplaning. wrote in message oups.com... Anyone else here ever experience one? How did yours happen? Mine have been ag related and hit ground, rocks, birds, and ? Ever throw off a piece of the prop blade? I lost a piece during climbout of a jungle strip in the Amazon in a C-185. Managed to dead stick it back without any further damage but it took nearly two months to get a replacement. IN the meantime, I used a field expedient and cut off an equal amount from the other blade. We were about 200 miles from civilization on the Rio Curaray. Ah the fun old days.... Ol S&B |
John
In that same vein, with winter conditions, how about the frozen humps from snow plows that are waiting to get the nose gear struts with attendant prop strikes or linkage damage? Owwww Ol S&B |
On Wed, 26 Jan 2005 05:50:38 -0000, John Godwin
wrote: wrote in roups.com: Anyone else here ever experience one? Yeh. How did yours happen? The airport decided to construct a concrete drainage depression across the taxiway. They have one here at COS, just like that, and it gets someone it seems atleast once a year. Scott D To email remove spamcatcher |
![]() "Cub Driver" wrote in message ... On 25 Jan 2005 16:11:39 -0800, wrote: Anyone else here ever experience one? How did yours happen? My instructor was explaining how to make a wheel landing. I just planted the thang too dang hard. I heard this whup! but we both thought it was just the bungee cords complaining: it was a very firm landing. "I'll take it around, and you follow me on the controls," says he. So we did. Then I taxied up to the pump and shut down, and I tell you, it is a sinking feeling to gaze at your prop and notice that the ends have somewhat melted and are curving in toward the cockpit. There wasn't the slightest vibration, or loss in performance that either of us noticed on that last circuit. No damage to the engine, and as commander of the aircraft, the instructor's insurance company had the privilege of paying for the prop. My technique has improved a lot since then. As has the instructor's I hope. The decision to go around after he heard the "whump" was in my opinion anyway, a bad one. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
Dan
I had a similar landing incident when the very experienced ag pilot in the front seat "stuck" the aircraft with positive forward stick on touchdown and put sand marks about 6" up the prop blade and bent the blades. We didn't follow up with any take off though. He was using his usual technique of forward stick with the Stearman he had been using for spraying and this time it didn't work on the Champion Scout we were flying. I was showing him the aircraft and it was his first flight in it. There is more to the story and in retrospect it's humorous but nontheless serious. Ol S&B |
![]() wrote in message oups.com... Anyone else here ever experience one? How did yours happen? Mine have been ag related and hit ground, rocks, birds, and ? Ever throw off a piece of the prop blade? I lost a piece during climbout of a jungle strip in the Amazon in a C-185. Managed to dead stick it back without any further damage but it took nearly two months to get a replacement. IN the meantime, I used a field expedient and cut off an equal amount from the other blade. We were about 200 miles from civilization on the Rio Curaray. Ah the fun old days.... Ol S&B My prop strike was in an ultralight, an Sorrell SNS-8, in Billings. I was practicing short field landings (for going into rancher friends' strips) and braked too hard. Slowly...over it went. Cost about $500 in (2-cycle) engine repairs, plus a new prop. John Lowry Flight Physics |
![]() Upper Cowl separated on one side on my Arrow in flight - wind blew it up on the windshield and since the other side remained attached, it twisted and put about a 1/8 inch dent in the back of both blades. Mechanic insisted I tear the whole #$&$ engine apart. One blade turned out to be out of spec, couldn't find replacement 2blade prop, ta da ta da da da. That's how it goes with airplanes. At least I know the engine is nice & clean inside and the new 3 blade prop looks nice. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 09:41 PM |
