ClearNav Vario Spoiler Warning
Old February 3rd 15, 12:11 AM posted to rec.aviation.soaring
Dan Marotta
Default ClearNav Vario Spoiler Warning
I finally completed installation of my new CNv XC vario and am having
problems with the gear/spoiler warning logic.
In my installation, while sitting on the trailer, opening the spoiler
causes the Spoiler warning to flash and sound off. This happens without
respect to the gear position or switch reading. Reading the switches in
the Info section of the CNv, I see that both switches are correctly
wired and functioning (both show 0 and 1 status as appropriate).
Is it possible that this is a ground test function and I won't know if
everything works as intended until my first takeoff?
Dan Marotta
Old February 3rd 15, 02:21 AM posted to rec.aviation.soaring
having problems with the gear/spoiler warning logic.
spoiler causes the Spoiler warning to flash and sound off.* This
happens without respect to the gear position or switch reading.*
Reading the switches in the Info section of the CNv, I see that both
switches are correctly wired and functioning (both show 0 and 1
if everything works as intended until my first takeoff?
Dan Marotta
Is what you are seeing a "spoilers open" warning (during takeoff roll) vs. a "gear up" warning?
Old February 3rd 15, 02:52 AM posted to rec.aviation.soaring
Tango Eight
Dan Marotta
Is what you are seeing a "spoilers open" warning (during takeoff roll) vs.. a "gear up" warning?
Yes, exactly.
Evan Ludeman for CNi
Old February 3rd 15, 10:45 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
Hi Dan
In case the rather shorthand answers have still left things unclear,
the system is working correctly for Gear and Spoiler Warnings
active.
In most ships you don't want to roll with spoilers open, so
have that warning active. Spoilers open, gear down, no
airspeed is a warning and SPOILERS will show on the screen.
For LS8/ASW24 or whatever where you want to roll with them
open until you have good roll control, disable the warning.
You will still get a warning (with Gear Warning enabled) if
you open spoilers with gear up. You can test the spoiler
warning function is correct by pressurising pitot to
50 knots, opening the spoilers should then give no warning
unless the gear is up.
Peter.
am
=20
=20
=20
off.=A0 This
reading.=A0
that
bot=
h
and 1
=20
=20
=20
know
=20
=20
--=20
=20
Dan Marotta
=20
takeoff roll)
vs=
Old February 3rd 15, 03:12 PM posted to rec.aviation.soaring
Dan Marotta
Thanks Evan and Peter. If the winds are light enough to rig today, I'll
try it out.
Dan
On 2/3/2015 3:45 AM, Peter Purdie wrote:
Hi Dan
active.
Peter.
am
=20
=20
=20
off.=A0 This
reading.=A0
that
bot=
h
and 1
=20
=20
=20
know
=20
=20
--=20
=20
Dan Marotta
=20
takeoff roll)
vs=
Dan Marotta
Old February 3rd 15, 03:30 PM posted to rec.aviation.soaring
John Firth[_4_]
In my book, warnings for take off roll and landing approach should be
audio, not on the panel. To divert your attention from outside risks a
ground loop or worse.
During takeoff, the only point at which I glance at the ASI
is after I have three axis control.
JMF
try it out.
Dan
Hi Dan
active.
Peter.
am
off.=A0 This
reading.=A0
that
bot
h
and 1
know
Dan Marotta
takeoff roll)
vs
Dan Marotta
Old February 5th 15, 08:14 PM posted to rec.aviation.soaring
Testing: Rosebud was his sled.
Nope, didn't work.
Old February 6th 15, 12:45 AM posted to rec.aviation.soaring
For those wanting a gear warning with voice, another option is the Tassman.
It allows you to record your own voice.
Something like..."Hey STUPID !! Lower the gear!"
No confusing that with the other beeps, clicks, whistles and such in our quiet cockpits.
ClearNav Vario and XCSoar Dan Marotta Soaring 9 January 2nd 15 11:33 PM
New ClearNav CNv Vario LCD Display Paul Remde Soaring 5 June 20th 14 11:53 PM
WTB Clearnav Xcountry Vario Go Soaring Soaring 0 January 26th 14 01:29 PM
More Vario Questions - ClearNav SteveB_Z5 Soaring 4 June 12th 12 02:24 AM
ClearNav Vario Paul Remde Soaring 5 January 8th 11 11:34 PM
