I'm trading in my CAI-302 for a ClearNav XC vario. Looking at the setup
screen in XCSoar, there's no listed driver for the CNv vario. The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data. Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet? My new vario should arrive some time next week... -- Dan Marotta |
On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote:
I'm trading in my CAI-302 for a ClearNav XC vario.* Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario.* The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data.* Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet?* My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave |
On Tuesday, December 30, 2014 7:30:55 PM UTC-6, Dave Leonard wrote:
On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario.* Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario.* The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data.* Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet?* My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier? Herb |
Thanks Dave,
I spent the day yesterday with my panel at the dining room table. I have all the wires brought out the panel hole and labeled, waiting for the connector. Just about finished with cleaning up 13 years of wiring modifications. I'll spend some time on the couch getting acquainted with the new unit... Dan On 12/30/2014 6:30 PM, Dave Leonard wrote: On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario. Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario. The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data. Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet? My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave -- Dan Marotta |
On Wednesday, December 31, 2014 9:58:45 AM UTC-5, wrote:
On Tuesday, December 30, 2014 7:30:55 PM UTC-6, Dave Leonard wrote: On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario.* Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario.* The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data.* Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet?* My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier? Herb Not completely (sorry). !w (air data) and !g (bugs, ballast, Mc) are fully supported. Task entry/declaration and file d/l over serial connection are *not* supported! Attempts to put CNv in command mode will cause data transmission to stop. best, Evan Ludeman for CNi |
On Wednesday, December 31, 2014 11:17:38 AM UTC-5, Tango Eight wrote:
On Wednesday, December 31, 2014 9:58:45 AM UTC-5, wrote: On Tuesday, December 30, 2014 7:30:55 PM UTC-6, Dave Leonard wrote: On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario.* Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario.* The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data..* Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet?* My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier? Herb Not completely (sorry). !w (air data) and !g (bugs, ballast, Mc) are fully supported. Task entry/declaration and file d/l over serial connection are *not* supported! Attempts to put CNv in command mode will cause data transmission to stop. best, Evan Ludeman for CNi btw, if anyone wants to discuss this further, let's take it over he http://clearnav.net/simplemachinesfo...hp?topic=181.0 best, Evan Ludeman for CNi |
Been trying to establish an account on the ClearNav forum. The page
says an email has been sent, but I'm not receiving it. Checking my spam folder, too. My username has been registered so I can't go on without that email... On 12/31/2014 9:39 AM, Tango Eight wrote: On Wednesday, December 31, 2014 11:17:38 AM UTC-5, Tango Eight wrote: On Wednesday, December 31, 2014 9:58:45 AM UTC-5, wrote: On Tuesday, December 30, 2014 7:30:55 PM UTC-6, Dave Leonard wrote: On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario. Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario. The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data. Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet? My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier? Herb Not completely (sorry). !w (air data) and !g (bugs, ballast, Mc) are fully supported. Task entry/declaration and file d/l over serial connection are *not* supported! Attempts to put CNv in command mode will cause data transmission to stop. best, Evan Ludeman for CNi btw, if anyone wants to discuss this further, let's take it over he http://clearnav.net/simplemachinesfo...hp?topic=181.0 best, Evan Ludeman for CNi -- Dan Marotta |
Looks like I won't have much trouble making the switch. Using my Streak
via K6BT, I've only changed bugs, ballast, and MC setting. I do use the download flights feature with the 302 but I don't see much problem with USB download. I'll either put a connector through the panel for that or just dangle the extension cable out the back for use after landing. Not concerned with contest flying or landouts. On 12/31/2014 9:39 AM, Tango Eight wrote: On Wednesday, December 31, 2014 11:17:38 AM UTC-5, Tango Eight wrote: On Wednesday, December 31, 2014 9:58:45 AM UTC-5, wrote: On Tuesday, December 30, 2014 7:30:55 PM UTC-6, Dave Leonard wrote: On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario. Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario. The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data. Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet? My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier? Herb Not completely (sorry). !w (air data) and !g (bugs, ballast, Mc) are fully supported. Task entry/declaration and file d/l over serial connection are *not* supported! Attempts to put CNv in command mode will cause data transmission to stop. best, Evan Ludeman for CNi btw, if anyone wants to discuss this further, let's take it over he http://clearnav.net/simplemachinesfo...hp?topic=181.0 best, Evan Ludeman for CNi -- Dan Marotta |
Figured it out. I'm registered now.
On 12/31/2014 10:04 AM, Dan Marotta wrote: Been trying to establish an account on the ClearNav forum. The page says an email has been sent, but I'm not receiving it. Checking my spam folder, too. My username has been registered so I can't go on without that email... On 12/31/2014 9:39 AM, Tango Eight wrote: On Wednesday, December 31, 2014 11:17:38 AM UTC-5, Tango Eight wrote: On Wednesday, December 31, 2014 9:58:45 AM wrote: On Tuesday, December 30, 2014 7:30:55 PM UTC-6, Dave Leonard wrote: On Tuesday, December 30, 2014 5:52:27 PM UTC-7, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario. Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario. The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data. Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet? My new vario should arrive some time next week... -- Dan Marotta I did the 302 for CNv swap a while back. Drop in replacement. Same XCSoar settings, same in flight functionality. (IOIO box and Streak running XCSoar) Turnpoint database load, task declare, vario config and log download are different. The CNv uses a USB stick to do all that. -Dave Does that apply to WinPilot (Pro) as well? Drop-in replacement? Connectivity to Avier? Herb Not completely (sorry). !w (air data) and !g (bugs, ballast, Mc) are fully supported. Task entry/declaration and file d/l over serial connection are *not* supported! Attempts to put CNv in command mode will cause data transmission to stop. best, Evan Ludeman for CNi btw, if anyone wants to discuss this further, let's take it over he http://clearnav.net/simplemachinesfo...hp?topic=181.0 best, Evan Ludeman for CNi -- Dan Marotta -- Dan Marotta |
Dan, I did the exact set up last year: 302 to CNv with XC Soar. The CNv will control XCSoar, but not vice versa. It will kill the comm like Evan stated.
Really has not been a problem, though. I'm happy. Tim On Tuesday, December 30, 2014 8:52:27 PM UTC-4, Dan Marotta wrote: I'm trading in my CAI-302 for a ClearNav XC vario.* Looking at the setup screen in XCSoar, there's no listed driver for the CNv vario.* The XCSoar Manual also says nothing about the CNv vario though it states that it will work with any vario which outputs NMEA data.* Both my Android phone and my Dell Streak 5 connect via bluetooth and work great. Has anybody tried this combination yet?* My new vario should arrive some time next week... -- Dan Marotta |
New ClearNav CNv Vario LCD Display | Paul Remde | Soaring | 5 | June 20th 14 11:53 PM |
WTB Clearnav Xcountry Vario | Go Soaring | Soaring | 0 | January 26th 14 01:29 PM |
ClearNav CNv vario software update | Evan Ludeman[_4_] | Soaring | 5 | April 17th 13 12:28 AM |
More Vario Questions - ClearNav | SteveB_Z5 | Soaring | 4 | June 12th 12 02:24 AM |
ClearNav Vario | Paul Remde | Soaring | 5 | January 8th 11 11:34 PM |
