Proairsport. New ultra light glider/airplane
Old March 17th 15, 07:23 PM posted to rec.aviation.soaring
ND
Default Proairsport. New ultra light glider/airplane
On Tuesday, March 17, 2015 at 1:56:56 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Curious what wings it's using. From the "airframe section" on their webpage, sorta sounds like they're using wings that are already "JAR certified", thus on an existing aircraft......
isn't it obvious? they look suspiciously similar to PW5 wings, and have the same span....
Old March 17th 15, 07:54 PM posted to rec.aviation.soaring
Bruce Hoult
Pod and canopy look like PW5 (except for pointed nose). Undercarriage position is PW5. Only the boom and tail feathers are significantly different. Even the maximum weight is the same, though the empty weight is 10 kg less, despite the engine and funky powered dual mainwheel.
Old March 18th 15, 12:48 AM posted to rec.aviation.soaring
George Haeh
The PW-5 lawn darts over 50 kt. It takes a
bunch of work to go places, but the thing
has a nose for thermals.
Pulling up the wheels might flatten the
polar.
Finding space for the battery, jet and fuel
looks a challenge.
If the fuselage will accept PW-5 wings,
there's lots of PW-5s that might convert.
Old March 18th 15, 05:11 AM posted to rec.aviation.soaring
Bruce Hoult
I've flown one or two hours in PW5, and even a few 250 or 300 km flights. It's worth flying 60 or 65 knots between thermals, but yes serious lawn dart by 80 knots (500 fpm down, 16:1)
Pulling up the wheels might flatten the polar.
Doubt it. It's the very thick wings hurt it at speed. Personal experience says Januses and DG1000 Clubs both go just fine at 100 knots with the wheel hanging out.
Old March 18th 15, 05:57 PM posted to rec.aviation.soaring
PBA
This thing looks awesome! I want one.
Old March 18th 15, 10:19 PM posted to rec.aviation.soaring
Vaughn
On 3/16/2015 10:39 PM, Bruce Hoult wrote:
On Tuesday, March 17, 2015 at 2:56:19 PM UTC+13, GR8 wrote:
http://www.proairsport.com/
Those close-set main wheels aren't going to keep it level on rough ground.
Electric powered wheels to help get to flying speed is a very good idea though. Acceleration is not jets strong point.
Since most of the energy for the launch (until you break ground, anyhow)
would be coming from the wheels, would this qualify as a ground launch?
Inquiring minds want to know...
Old March 18th 15, 10:23 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Sorry, Vaughn. It would be considered a self launch. But, just for special effect, it would be cool to put clorox on the tires, so you could do a burnout as you are taking off!
Old March 19th 15, 03:20 AM posted to rec.aviation.soaring
George Haeh
I wonder about the tire footprint on grass fields. We might be seeing the
tires digging little trenches.
Old March 19th 15, 02:15 PM posted to rec.aviation.soaring
I'm looking forward to the burnouts on asphalt! This is a silly idea. You're better off with a bungee cord to get to take-off speed.
Old March 19th 15, 02:22 PM posted to rec.aviation.soaring
Bruce Hoult
Why, other than the weight of the electric motor and battery?
Car tow would be better than bungee. But either needs to have someone else around to help.
mass of Ultra light thingies Glenn[_2_] Aviation Photos 0 September 9th 07 01:03 PM
Another ultra light thingy Glenn[_2_] Aviation Photos 0 September 9th 07 01:01 PM
Some Ultra Light thingy Glenn[_2_] Aviation Photos 0 September 9th 07 12:55 PM
Ultra light Glider regulations Denis G Soaring 5 May 24th 04 06:19 PM
Ultra Light Towing Randal Cullen Soaring 9 February 9th 04 05:41 AM
