Ultra Light Towing
Old February 5th 04, 10:33 AM
Randal Cullen
Default Ultra Light Towing
I've been informed that Czech does no allow ultralight
tow planes. Are you aware if this is the case in any
other countries? We are currently considering a SAMBA
as a tow plane for our club in South Africa.
Old February 6th 04, 06:49 AM
Doug Taylor
Randal Cullen wrote in message ...
In the United States, ultralight tow planes exist, but they are only
allowed to tow ultralight gliders and only if operated with a waiver.
The regulations define and ultralight glider as any glider with an
empty weight less than 155 pounds (70 kgs.) so it is mostly for hang
gliders but there are a number of other designs that meet the rule. I
have heard of cases where ultralight tugs have pulled much heavier
things (like an ASW 20) without much trouble (Don't know where that
happened so don't ask me ). It is certainly viable if your
regulations allow it.
Old February 6th 04, 06:47 PM
Robert John
I flew from the Wasserkuppe in a K-21 behind a 'Pellican'.
Not a pleasant experience. Downwind take-off from
their sloping runway. After a 180 degree turn we passed
the take off point looking UP at it! Their Robins,
on the other hand, are immaculate and get you up there.
Rob
At 10:54 06 February 2004, Martin Gregorie wrote:
On 5 Feb 2004 21:49:40 -0800,
(Doug Taylor)
Randal Cullen wrote in message news:...
but they are only
with a waiver.
glider with an
mostly for hang
meet the rule. I
much heavier
know where that
if your
They tow single seaters (ASK-23, ASW-24) at the Wasserkuppe
with the
trike gear Sinus/Virus type of all composite UL. Sorry
I don't know
the exact type: I just checked their web site but there
is no
information on the tugs there. However, they use a
Robin GR400 for
their ASK-21s
I had a launch in an ASK-23 there behind a UL. The
climb rate seemed
OK - certainly no worse than you'd get from a 160 hp
4 bladed Rallye.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old February 6th 04, 08:57 PM
Stefan
I've flown a Janus behind a G3-Mirage. It takes definitely longer to get
off the ground, but once airborne, the climb rate is nearly that of an
"ordinary" plane. The whole tow takes a bit longer, but due to the much
lower cost of the UL, it's still much cheaper.
I'd say it works fine from a paved runway or from a long grass runway.
Not recommended from short runways or with a tailwind, especially if the
rope break options are difficult or if there are obstacles at the end of
the runway.
Stefan
Old February 7th 04, 06:34 AM
Andreas Maurer
On Fri, 06 Feb 2004 20:57:58 +0100, Stefan
the runway.
I heard from a reliable source that aerotow tests with a single-seater
(iirc Ventus) behind an Impule 100 with a 100 hp Rotax 912S showed a
climb rate of more than 1.000 fpm... (!). This might be the first
ultralight that is a full replacement for a Remorqeur, even on
less-than-perfect conditions.
It helps significantly if the tow plane is aerodynamically clean.
The G3 Mirage and Mattin Wezel's Condor are NOT clean.
Bye
Andreas
Old February 7th 04, 10:34 AM
Bruce Greeff
the runway.
Bye
Andreas
Where could we get more information on said Impule ultralight?
Bruce
Old February 7th 04, 04:13 PM
Andreas Maurer
On Sat, 07 Feb 2004 11:34:31 +0200, Bruce Greeff
www.impulse-aircraft.de
Bye
Andreas
Old February 7th 04, 04:17 PM
"Bruce Greeff" wrote in message
Bruce
A Google search for "Impule ultralight" yielded nothing: however, "Impulse
ultralight" provided several links including the following:
http://www.impulse-aircraft.de/english/home/firma.html
http://www.soaridaho.com/
Old February 9th 04, 06:41 AM
Bruce Greeff
Bruce
Thanks - I got the same and was wondering if it was a typo, or not.
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 07:49 PM
C-172 landing light switch JFLEISC Piloting 16 May 6th 04 02:15 AM
C-172 landing light switch JFLEISC Owning 10 May 6th 04 12:05 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 11:09 PM
