PowerFlarm Update Problem
Old April 15th 15, 01:46 PM posted to rec.aviation.soaring
John Carlyle
Default PowerFlarm Update Problem
Dan, I disconnected the display this morning and tried upgrading. No joy, same results as described above. I think my PF core has lost the ability to read USB thumb drives. If it wasn't for the mandatory firmware upgrade, I think everything else would be working just fine. Thanks for your tip!
-John, Q3
On Tuesday, April 14, 2015 at 9:57:50 PM UTC-4, Dan Daly wrote:
I've found I have 100% success when I disconnect the Butterfly Display, then power up with usb in, and 0% when it is connected (mine is an early core, 169). Once it is done, I reconnect and check it went through. I was a beta tester for 2.7 and it was suggested as a good idea. Adds a couple of seconds but has proven to be a good idea - for me at least.
USB 2 less than 32 GB is required for the stick.
Dan
Old April 15th 15, 02:46 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
I thought 6.0 was for the brick and 6.02 was only for the portable units to correct a problem that only applied to the portable.
JJ
Old April 15th 15, 10:33 PM posted to rec.aviation.soaring
Ramy[_2_]
JJ
My understanding is that if you already upgraded a brick to 6 you dont have to upgrade again to 6.02. Only the portables need the upgrade. But wouldnt hurt to upgrade the brick as well.
Ramy
Old April 15th 15, 10:35 PM posted to rec.aviation.soaring
Paul Remde
HI JJ,
There is only one software for both the Core and the Portable. The bug fix
in version 6.02 is only needed in the Portable - so there is no pressing
need to upgrade a Core from 6.00 to 6.02. 6.00 is no longer available.
6.02 works great in both Core and Portable units.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
______________________
"JJ Sinclair" wrote in message
JJ
Old April 15th 15, 11:20 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I have seen some USB sticks that just wouldn't communicate - if you format them it has always solved the problem.
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 03:13 PM
PowerFlarm Update? Mike the Strike Soaring 71 March 21st 15 05:32 PM
I need help with PowerFlarm problem Andy K Soaring 11 July 23rd 14 09:53 AM
Portable PowerFlarm hardware update kd6veb Soaring 8 March 22nd 13 10:44 PM
PowerFLARM Display Update Paul Remde Soaring 2 November 11th 10 06:40 PM
