I need help with PowerFlarm problem
Old July 19th 14, 09:06 PM posted to rec.aviation.soaring
Andy K
Default I need help with PowerFlarm problem
Here is my configuration:
PowerFlarm brick and Trig T22 mod S transponder. PowerFlarm configured with the transponder code to disregard it.
I get constant notifications of my own transponder; yesterday probably 100 times, not kidding. I will have to unplug LX9000 from the PowerFlarm as it is not possible to use it as the PowerFlarm warnings just take over the screen.
I have had this problem with ASG-29 and ASH-26E. In the first glider the PowerFlarm antenna was set up high over the glare shield in the second glider (the 26E) the PowerFlarm antenna is in the fuselage cone as front part of the fuselage does not have any carbon. The 26E has a transponder antenna at the gear door. There is no carbon interference between the two antennas. I have good coverage as proven by experience flying with others.
Any help how to get to the root cause of this problem is appreciated. I can accept sporadic alerts but yesterday it was simply unacceptable.
On the other hand it was really nice to see a couple of twins with ADS-B out doing big circles around me.
AK
Old July 19th 14, 10:54 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
AK
As an interim step you can set the pcas range to zero in flarmcfg.txt file and this will turn off mode C/S but leave adsb on.
T8
Old July 19th 14, 11:48 PM posted to rec.aviation.soaring
Darryl Ramm
AK
An issue here is that you can correctly set the type and ICAO ID of your transponder in your FLARM so that the Flarm will ignore the Mode-S replies of that transponder. However every Mode S transponder also has to reply to Mode C interrogators, and when your Trig TT-22 does that, there is no ICAO address included in that transmission and your PowerFLARM then has to reply on altitude correlation (and RF power) to guess this is the local transponder. But it should be pretty good at doing this becuase it should be reading the Mode-S altitude from the transponder. You might get into problems where you have very spotty interrogations, or mostly Mode-C only interrogations (e.g. if below say SSR radar coverage and being interrogated by older GA TCAD systems which issue Mode C only interrogations). If you are anywhere near busy airspace/civil or military SSR radar covered airspace that issue should not happen.
Double check you have *all* the PowerFLARM settings correct including transponder type (must be mode S.. that gets the PowerFLARM using the transponder's own altitude) and have the correct ICAO code entered without any base conversion errors.
Check all your cables and cables, try swapping the FLARM 1090MHz antenna/cable with known good ones.
Earlier ASH-26Es had fairly poorly installed transponder antennas right behind the gear doors. If yours is like that you really should install the antenna from behind the engine bullhead (requires engine removal) as described in the current TN. I'd do that even if a current install right behind the gear door appeared to be OK with biannual transponder tests. Use new RF cable and put the TT-22 RF box as close as you can to the antenna... ideally mounted remote behind that engine bullhead.
I don't understand what you mean by "carbon interference". I'd be surprised but it might be possible there is too much carbon/ground plane obstructing the transponder signal to the PowerFLARM.
Are there warning happening in flight at decent altitude? Or when low or on tow (does the tow plane have a transponder?). Are there any nearby transponder equipped gliders? Where exactly are you flying/at what altitude (covered by what SSR facility etc.).
If you can't track down anything I would try borrowing a PowerFLARM Portable from somebody to do an A/B test with.
Old July 20th 14, 01:19 AM posted to rec.aviation.soaring
Andy K
AK
Darryl,
thank you for your post. I saw the same issue with this PowerFlarm box in my ASG-29 where Transponder antenna was installed in the fin by Schleicher. Between the 29 and the 26E the only thing common was the PowerFlarm. In the 29 the PF antenna was mounted at the top of the glare shield.
In the ASH-26E the transponder antenna was installed behind the gear door by Schleicher. I will take a look at the location.
In regards to "carbon interference" I don't see any in terms of direct line..
Strangely enough I flew the ASH early June and I did not observe as many false warnings. I don't remember this being such a big deal this season until yesterday when it became impossible to deal with. I did not fly the 29 this year but in that glider I don't remember the false warnings to be constant. Yes they were annoying but I could deal with them.
Half of the area I flew in yesterday had good radar coverage the other half was spotty. I did not see big difference between PF noise level. I flew most of the day alone and there were no other gliders around. The false warnings where happening probably once a minute or so.
I will go over the PF configuration? Darryl, can you share with me your configuration file? I know I would need to change the transponder address, but I wonder about other parameters and their interaction e.g. bugs in PF software. There might be some specific configuration that I have that is causing these issues.
AK
Old July 20th 14, 01:58 AM posted to rec.aviation.soaring
Darryl Ramm
AK
Darryl,
thank you for your post. I saw the same issue with this PowerFlarm box in my ASG-29 where Transponder antenna was installed in the fin by Schleicher.. Between the 29 and the 26E the only thing common was the PowerFlarm. In the 29 the PF antenna was mounted at the top of the glare shield.
AK
My PowerFLARM is sitting in its box unused as is my glider. Just post your config file here. And the ICAO address you think is correct for your glider..
The false warnings were happening mostly when you believed you were inside or outside of SSR coverage? Exactly where and at what altitude were you flying when you had most false reports.
Old July 20th 14, 02:41 AM posted to rec.aviation.soaring
Andy K
AK
Darryl,
AK
I did not see any correlation in terms of radar coverage or not. My transponder was interrogated very frequently. Flying in the North East 4500-6000 feet. I flew in Nevada early in a Month (Ely) with some false warnings but they were very manageable. I guess I my transponder was not interrogated there.
Old July 21st 14, 12:20 AM posted to rec.aviation.soaring
Andy K
AK
Darryl,
AK
Here is the dump written to a file by PF Core
# Auto-generated file, don't edit!
2,PowerFLARM-Core,523,SWVER=3.40,REGION=USA,ID=AD3868,CALLSIGN= N951AK,ACFT=1,CAP=OBST;RFB;TIS;IGC;ENL;DLED;USBH;D P2;XPDR,LIC=AUD:0;ENL:0;IGC:1;RFB:1;TIS:1,XPDR=2,C AL57=372
As you can see the transponder code in PF is correctly set to AD3868. The transponder is also set to AD3868. It is Trig T22.
How do you get a full configuration file dump in PF that includes alert distance and vertical separation?
AK
Old July 21st 14, 01:07 AM posted to rec.aviation.soaring
Darryl Ramm
AK
Darryl,
AK
AK
And importantly you have Transponder type set to 2 for Mode S, which getting wrong is a cause of these type errors as well. The first mention of XPDR in the dump just means the 109ES receiver licenses capability is enabled.
I can't recall the dump options, are you using "$debug_out,fat,all,all", you can also just your riginal config file.
Old July 23rd 14, 09:53 AM posted to rec.aviation.soaring
Hi Andy,
can you send me IGC files of the flights in question, your FLARMCFG.TXT and your FLARMDEV.CSV to info at flarm.com?
If I get them by Friday, I can look into it, then I'm on vacation
for two weeks.
Best regards
--Gerhard
AK
Darryl,
AK
AK
Old July 20th 14, 04:11 PM posted to rec.aviation.soaring
John Cochrane[_3_]
I had exactly this problem at Minden. LX9000 and Mode S. The problem is that the powerflarm configuration file has the wrong / no transponder code in it. Reviewing the powerflarm configuration file carefully should fix it.
John Cochrane
PowerFlarm v3.40 Auxvache Soaring 35 April 24th 14 03:38 PM
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 05:56 PM
PowerFLARM 2.71...WTF? [email protected] Soaring 40 May 2nd 13 03:32 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
