FLARM Range
Old June 16th 15, 09:04 PM posted to rec.aviation.soaring
Papa3[_2_]
Default FLARM Range
Fun - Exactly!! The marked up config file supplied as an example doesn't actually relate to some of the options in the updated Configuration Tool.
I spent hours at Mifflin trying to get Karl Striedieck's Flarm Core to speak with his FlarmView. Tried bare-bones "default" and multiple other variations, but it never seemed to work completely. Part of the problem was several variables changing at once (Powerflarm software version update, config file update, Flarmview update).
On Tuesday, June 16, 2015 at 3:25:56 PM UTC-4, Andy Blackburn wrote:
On Tuesday, June 16, 2015 at 9:41:53 AM UTC-7, jfitch wrote:
In the V6 dataport manual, it says that anything set to 71 is going to revert to 1 at the next power up.
Apparently that's different for the new v7 Protocol - but I have not seen the new spec. Also apparently the protocol that needs to be used may depend on the device that's connected -- and some devices configure the protocol themselves.
Wheeeee! Fun!
9B
Old June 16th 15, 11:44 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default FLARM Range
Yeah. Between what's in the (now 1 version behind) Dataport Specification, the (partly out of date) commented FLARMCFG.TXT file, some undocumented configuration commands I got last year and the (hopefully) upcoming Configuration Manual, I hope to get a better handle on this. Obviously not all of those things are going to be 100% consistent. The interplay between PowerFLARM firmware and the various device firmware updates also makes it pretty challenging without some inside knowledge - or known good configurations - to work with.
It's a pretty sophisticated piece of technology. I'm thankful it works as well as it does.
9B
Flarm range Ramy[_2_] Soaring 7 May 7th 15 11:02 PM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
long range aircraft flying short-range routes? tupolev204 Piloting 10 April 22nd 11 07:44 PM
What is the range of the B-1B? user Military Aviation 10 December 24th 03 04:15 AM
Fuel Range Toks Desalu Home Built 2 November 14th 03 12:51 PM
