Hey all,
I'm in the process of writing my response to the FAA's ANPRM on transponders in gliders. One of the items covered in the document is TABS (Traffic Awareness Beacon System) under TSO-C199. Does FLARM come under this TSO? I hadn't heard of TABS before reading the ANPRM, and while it talks of low cost avoidance systems it doesn't give any examples. Thanks. Mark Palmer Greenwood Village, CO |
On Monday, August 3, 2015 at 10:50:41 AM UTC-5, Mark Palmer wrote:
Hey all, I'm in the process of writing my response to the FAA's ANPRM on transponders in gliders. One of the items covered in the document is TABS (Traffic Awareness Beacon System) under TSO-C199. Does FLARM come under this TSO? I hadn't heard of TABS before reading the ANPRM, and while it talks of low cost avoidance systems it doesn't give any examples. Thanks. Mark Palmer Greenwood Village, CO Hi Mark, Unfortunately, no. FLARM would not be an approved TABS device. And I hadn't heard anything of TABS before this ANPRM, either. Steve Leonard |
Thanks, Steve. That's what I thought but wanted to be sure.
Mark |
Out of curiosity, is there any equipment currently on the market that meets the TABS requirement?
Mark |
On Monday, August 3, 2015 at 11:06:16 AM UTC-5, Mark Palmer wrote:
Out of curiosity, is there any equipment currently on the market that meets the TABS requirement? Mark Nothing that I am aware of. Requirements were just finalized in October of last year. I would need to dig back through some discussions I have have with others, but think of TABS as pretty much a Mode S transponder with the GPS input for "extended squitter" or 1090ES out. There are some other differences, but that is probably the closest description you will find of "TABS in 100 words or less". Steve |
On Monday, August 3, 2015 at 11:00:01 AM UTC-7, Steve Leonard wrote:
On Monday, August 3, 2015 at 11:06:16 AM UTC-5, Mark Palmer wrote: Out of curiosity, is there any equipment currently on the market that meets the TABS requirement? Mark Nothing that I am aware of. Requirements were just finalized in October of last year. I would need to dig back through some discussions I have have with others, but think of TABS as pretty much a Mode S transponder with the GPS input for "extended squitter" or 1090ES out. There are some other differences, but that is probably the closest description you will find of "TABS in 100 words or less". Steve There are two parts of the TABS specification, Class A devices which is a slightly stripped down Mode-S transponder with 1090ES Out and Class B devices which are a GPS Source to provide the input to Class A TABS devices. Full Mode S/1090ES Out transponders can also meet the requirement of TABS devices, and so opens up the possibility of using a TABS Class B GPS to drive those for TABS use.... but for example that (currently at least) will not be usable to meet any of the 2020 ADS-B Out carriage mandate for (powered aircraft). And since TABS only exists as a TSO for devices, there are TABS installation, carriage or use regulations *at all*... so anything beyond what the boxes technical specs are is totally unclear, and what the SSA should be workign on, what ends up happening with TABS could be useful or could be horrifically bad for gliding and other aviation segments. I expect/hope that being able to eventually meet FAA 2020 ADS-B Out carriage mandates for GA aircraft using (hopefully) lower-cost TABS Class B GPS sources is something that AOPA and EAA really want to see happen. There seems to be widespread confusion about TABS Class B GPS sources, while technical aspects of the TSO was written to make it possible to use some consumer GPS chipsets, that GPS product still needs to be manufactured by a TABS TSO holder, and has to meet specific complex tests (using a constellation simulator as described in the TSO spec). And in order to actually ship a "TSO'ed product" that manufacturer has to be licensed and working within the the regulated avionics manufacturing process in their country/regulatory area. So at least based on interpreting the current TSO, and understanding some of the concerns the FAA has about GPS technology, folks won't be connecting any old consumer GPS source to a TABS box or a Mode S Transponder. PowerFLARM does not transmit 1090ES Out (it does receive 1090ES In) so is not a candidate to be a TABS Class A device (but again it will "see" aircraft equipped with TABS Class A devices, which is great). And neither is it a TABS Class B device... it's easy to tell, it does not have a TSO-C199 sticker on the box :-) Doing the work to produce a TSO-C199 compatible version of PowerFLARM is something FLARM would have to talk to, but as things currently sit it is not a suitable GPS source for a TABS Class A device. NexNav have announced their Micro-i TABS Class B GPS source. I have no idea on pricing or availability. I suspect it is likely that Nexnav may only want to pursue the embedded/OEM market for products like this. Given the complexity of dealing with a TSO like the TABS TSO, it is quite possible that only existing GPS Avionics manufactures would produce TABS GPS sources... even if they actually use COTS GPS chipsets, so sorry to be a downer on all those "consumer GPS" hopes. Trig Avionics (who make *great* products) is using their TT-20 TABS device in trials in the UK, I don't think there is public information available on the TT-20 or any info on possible commercial availability of the TT-20. But clearly it is likely just a feature stripped TT-21. I suspect the TT-20 has an integral (OEMed) GPS source, if so then as a combined box would be both a Class A and B device. |
Darryl, I don't know how you can manage to keep on top of all this ADS-B stuff without your head exploding but thank you for doing so! Whenever I try to make sense of it all it makes me want to give up flying and take up Tiddlywinks or something.
Out of curiosity, what performance parameters in the PowerFLARM system make it a "degraded" GPS source unsuitable for ADS-B out? I assume the system must be accurate enough for airborne traffic awareness and collision warnings as it has proven satisfactory in FLARM to FLARM situations. |
On Saturday, August 8, 2015 at 11:44:09 PM UTC-7, wrote:
Darryl, I don't know how you can manage to keep on top of all this ADS-B stuff without your head exploding but thank you for doing so! Whenever I try to make sense of it all it makes me want to give up flying and take up Tiddlywinks or something. Out of curiosity, what performance parameters in the PowerFLARM system make it a "degraded" GPS source unsuitable for ADS-B out? I assume the system must be accurate enough for airborne traffic awareness and collision warnings as it has proven satisfactory in FLARM to FLARM situations. Everybody keeps thinking first about GPS accuracy, accuracy is just a small part of what makes a high-end aviation GPS like a TSO-C145c device. It's reliability, failure detection and predictability of that reliability that separate these from consumer devices. A TSO'ed/IFR GPS source used to meet the FAA 2020 Mandate such as TSO-C145c has to support RAIM for reliability purposes. PowerFLARM's consumer chipset based GPS source cannot do that.... and RAIM and other goodies are not transmitted over NMEA. TABS/TSO-C199 Class B GPS sources do away with the RAIM requirement (it's actually one of the big good things in that TSO). TABS/TSO-C199 Class A (the transponder/1090ES Out part) use HFOM (Horizontal Figure of Merit) and VFOM (Vertical Figure of Merit) for "GPS health", but NMEA does not send HFOM or VFOM data. That is why the TSO allows the Class A TABS device to calculate HFOM and VFOM from HDOP and VDOP which NMEA does provide (in $GPGSA). Or course a TSO-C199 Class B device might use NMEA, Aviation serial, NexNav serial binary, etc. It's worth noting that the first GPS product announced that is targeted at TABS Class B GPS source use is the NexNav Micro-i, and few details are available so far, but I expect it will transmit GPS data on both NexNav serial binary and NMEA serial links as their similar products do, and it does include RAIM support (which would require use of the NexNav binary serial link.... which the Trig TT-21/22 already support) even though that is not required for TABS... NexNav have likely largely just repackaged another of their products at reduced price. |
Flarm IGC files on non-IGC certified Flarm? | Movses | Soaring | 21 | March 16th 15 09:59 PM |
Guitar Chords/Tabs for "Ridge Runner" | [email protected] | Soaring | 3 | November 20th 08 05:00 AM |
IFR Alternate Requirement | gwengler | Instrument Flight Rules | 18 | May 18th 05 02:26 PM |
Mode S to become requirement? | Bob Chilcoat | Owning | 6 | July 14th 04 11:25 PM |
New Castle ELT Requirement | Ed Byars | Soaring | 16 | June 19th 04 06:15 PM |
