On Friday, October 30, 2015 at 7:06:39 PM UTC+2, Robert M wrote:
A new AD note has been issued by the FAA concerning the airbrake locking system of all models of the G-103 glider certificated in any category. This means it applies to G-103s in the EXPERIMENTAL category too. AD 2015-22-04 becomes effective 4 December 2015. And has two different compliance times. It is available at: http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet The AD references two Service Bulletins issued by the Type Certificate holder, Fiberglas Technik Rudolf Lindner GmbH in Germany. http://ltb-lindner.com/ The SBs are available at Lindner's web site. SB-G07 Instructions for installing an inspection opening to the underside of the wings. SB-G08 Instructions for checking the locking force of the airbrake system and adjusting it if necessary, and inspection the locking lever for cracks. It also calls for this inspection to be performed at each Annual Inspection. Lindner is working on a permanent fix which I assume would include replacing the locking lever in question. That may take a while. Many G-103s already have the inspection hole installed. They are a great help when doing the inspection for cracks in the locking lever and mandatory for adjusting the over center locking force. I highly recommend installing the inspection holes even if your initial inspection shows no cracks and the locking force is within limits, If you have questions contact me at 505 269-8234 Robert Mudd Composite Aircraft Repair Moriarty, New Mexico. The new AD is for the Twin IIs. The Twin Is had this for ages. The incident which triggered the AD had one airbrake pop open at the start of the tow. The instructor opened the other one, continued the tow and landed safely. Thankfully, the tug was a Pawnee :-) Subsequent inspection found another cracked bellcrank on another glider in the same club. Uri |
The kits for installing the inspection holes will include the correct epoxy resin and filler materials. The plexiglas cover/window is also included. As is noted in the instructions placement of the holes is critical as they are not in the same position on the LH wing as on the RH because of spar placement. Careful reading of the SB G07 is important.
I am collecting orders now for the kits and will have some on hand before the effective date of the AD note. Robert Mudd Composite Aircraft Repair ph 505 269-8234 |
We did ours this summer as in Canada EASA AD's on EASA made gliders come into effect upon issue. Fortunately the closing forces were within spec and there was no damage to the parts. It wasn't that bad except for the derigging, rigging, derigging, rigging cycle needed to get it to the maintenance shop and back and then into the air again.
One thing I was curious about is that our Twin II already has inspection ports in the wings near the airbrake system parts in question but unlike the inspection ports in our Twin Astir RG they don't seem to be large enough to allow removal of the brake parts through them. |
Grob gliders, new TM about control system pulleys | Robert M | Soaring | 5 | February 14th 14 04:47 PM |
Grob 102 Spar Spogot AD note | [email protected] | Soaring | 0 | January 10th 11 08:45 PM |
Grob 103 AD note for bolt, USA | [email protected] | Soaring | 2 | March 2nd 09 05:47 PM |
Grob G-103 AD note, USA | [email protected] | Soaring | 1 | February 27th 09 11:05 AM |
Grob AD note. Stemme AD note. | pbc76049 | Soaring | 0 | August 21st 06 03:23 PM |
