Grob 102 Spar Spogot AD note
Old January 10th 11, 08:45 PM posted to rec.aviation.soaring
Default Grob 102 Spar Spogot AD note
Dear G-102 owners,
The FAA has finally issued the an AD note covering the Grob SB 306-29
and TM 320-5 dealing with the replacement of the spar spogot
assemblies on the G-102 series gliders. Read the AD on the FAA web
site for full understanding of its details.
Parts are avilable, in fact I have a few sets here in Moriarty. Enough
for every G-102 effected can be obtained. The lead time for replacing
the spigots is 15 months from the effective date of the AD note which
is 14 Feb. 2011. Happy Valentines Day.
I thought the AD would be issued eventually but had no idea it was
comming this month. I have some planing to do before starting on the
actual work but should be ready about the time the AD becomes
effective.
I expect turn around time will be on the order of 2 weeks, and I'll
invest in what ever tooling needed to do the work in an efficent way.
There is a high probility that I will be the only shop authorized to
do the work.
If you have a G-102 that is effected by the AD send me an E-mail and
I'll creat a mass mailing list to up date owners.
Robert J. Mudd
ph 505 269-8234
Composite Aircraft Repair LLc
Moriarty, NM 87035
Grob 103 AD note for bolt, USA [email protected] Soaring 2 March 2nd 09 05:47 PM
Grob G-103 AD note, USA [email protected] Soaring 1 February 27th 09 11:05 AM
Grob G102 Astir Spar Spigot Assembly AD NPRM BDS Soaring 4 August 30th 07 04:13 PM
Grob Astir AD spar spigots toad Soaring 20 May 19th 07 04:57 PM
Grob AD note. Stemme AD note. pbc76049 Soaring 0 August 21st 06 03:23 PM
