Dittel radio squelch
Old September 23rd 16, 05:33 AM posted to rec.aviation.soaring
ZP
Default Dittel radio squelch
I'm having the same problem with mine without any converters in the circuit and am interested in trying the squelch adjustment. Thanks for the help.
Old September 23rd 16, 02:19 PM posted to rec.aviation.soaring
I have found the Cambridge GPS is always the first suspect, with the SN-10 close behind + cheap voltage converters, but almost everything will add some noise. Try turning on your radio with no squelch applied, then listen as the other electrical devices are turned on. The hiss will slowly build until it becomes a roar. Turning down the internal squelch is placing a band-aid over the problem. Did you hear the guys 60 miles away, climbing under Cu's?.......... I did!
:) JJ
Old September 26th 16, 12:26 PM posted to rec.aviation.soaring
Karl Striedieck[_2_]
There is a pot that adjusts the squelch. I have it marked on my FSG-50. If you are interested contact me karls at uplink.net
KS
Old September 26th 16, 04:38 PM posted to rec.aviation.soaring
With the bottom pan off (4 screws) and looking down at the bottom innerds with the front toward you the pot to adjust is 3 and 3/4 inches back from the front face of the radio. It is on the extreme right, has red sealing paint on it and is just in front of a big rectangular something that is labeled "A3411P" on my radio.
Email me if you want a pic karls at uplink dot net.
KS
Old September 26th 16, 04:45 PM posted to rec.aviation.soaring
PS Turn counterclockwise for more squelch (less noise).
KS
Old September 27th 16, 07:21 AM posted to rec.aviation.soaring
Sig_ZA
KS
What I did was to drill a small hole in the cover, above the squelch pot. That way when making small adjustments. The cover need not be removed.
Old October 3rd 16, 08:03 PM posted to rec.aviation.soaring
Just found yet another electronic device that will break squelch on your radio..............your smart phone!
The buyer of my D-2, sat down to see how he fit. The radio broke squelch..........when he turned off his smart phone, the radio went silent again.
JJ
Old October 3rd 16, 08:34 PM posted to rec.aviation.soaring
Bruce Hoult
JJ
What kind of cell coverage did you have there at the time?
Old October 3rd 16, 09:38 PM posted to rec.aviation.soaring
3 bars most of the time.
Old October 3rd 16, 10:36 PM posted to rec.aviation.soaring
Bruce Hoult
Yes, but GSM, 3G, LTE?
Dittel FSG71 Radio / Squelch Questions Bastoune Soaring 15 June 12th 18 04:20 PM
Dittel FSG 60M....Where is the internal Squelch adjustment pot? vtcyclist Soaring 1 September 20th 16 01:28 AM
Radio manual or squelch setting question - UNIMOR RADIOCOM RS 6112 Dan Daly[_2_] Soaring 0 July 16th 15 01:22 AM
Dittel FSG-50 Adjustable Squelch Modification Jim Vincent Soaring 2 April 13th 11 08:45 PM
Static/Squelch Noise in Radio Kensandyeggo Home Built 2 April 13th 06 09:00 PM
