#11
On Thursday, October 6, 2016 at 8:46:14 AM UTC-4, wrote:
Funny. I find when my trailers (2 Cobras and a Solaire) starts to oscillate that a quick hard jab on the brakes stops all the bad motions. Doesn't make any difference whether the oscillations are started by an 18 wheeler passing me or by my increasing my speed too much. Acceleration just seems to amplify the swings. I do find that making sure the trailer is very tongue heavy makes it stable and that tongue light makes it unpredictable. How do you go about making the tongue light as you describe? UH |
Ironic that there is zilch about loading-towing a glider trailer on the PPL-Glider written test, but there're a bunch of questions about VOR.
I always thought that part of the practical test should be being presented with a mystery trailer light problem to solve, with a time limit.
Ok not realistic for the FAA test but could be a good addition to the Bronze Badge test ![]() |
Don.
You need to update your driving knowledge - the UK speed limits for towing a trailer is 60mph https://www.gov.uk/speed-limits At 17:13 05 October 2016, Don Johnstone wrote: At 14:59 05 October 2016, Charlie M. UH & 002 owner/pilot wrote: I've wondered if adding a small (1/4" - 3/8") anti sway bar to th trailer axle would help in most situations. Granted, proper weight is best, bu the anti sway bar may widen the margin. Thoughts? Weighting is important, no doubt. Reducing the weight and therefore th inertia on the anchored end of the trailer does reduce the possibility o any swing increasing by increasing the ability of the towing vehicle t damp the oscillations. The trigger for these oscillations is aerodynami caused by the low pressure area between two vehicles as they overtake/ar overtaken. The situation is made worse if the vertical surface is the sam or more than the area in front of the axle. Cobras and Komets are designe to reduce the side area behind the axle. I towed a trailer, containing a Grob 103 back from Holland. The nose weigh was close to the maximum limit allowed for my car, theoretically the bes situation to improve stability, however it swayed readily. I have jus towed the same combination over 300miles. Before leaving I increased th tyre pressures on the trailer from 35psi to 55psi (Max 65psi). The traile now tows with no swaying up to the maximum speed limit in the UK (70mph) It does allow towing at just below 60mph which means I can avoid bein overtaken by large trucks, the condition which is most likely to trigge swaying. Tyre pressure appears to have a large influence on the stabilit of the trailer, greater than loading. Vertical instability is now the majo problem, easily fixed by a stabiliser. |
Still waiting for feedback from "ME" types on this.
Tire pressures have a bit on this. Had a large reply earlier (got lost for whatever reason) that is not here. Most recent glad to not read through it. Basically, high trailer tire pressures may limit swaying, it also intrudes shock loads to mechanical instruments. "Fix one thing, FUBAR another thing.....". |
At 13:57 07 October 2016, Dave Martin wrote:
Don. You need to update your driving knowledge - the UK speed limits for towin a trailer is 60mph https://www.gov.uk/speed-limits I know that, as I should. My point was that adding 20psi to the tyre pressure changed the handling of the trailer from unstable at 50mph to steady at 20mph faster. I suspect that a faster speed would be possible but it was unnecessary to test as a 10mph excess over the limit of 60mph was enough to show that just increasing the tyre pressure was a partial answer to the problem we had, and give a reasonable margin. Being able to tow at 60mph means that I was able to avoid being overtaken by large Artics governed to 56mph, avoiding the main condition that triggers swaying, being restricted to 50mph did not allow that. Police generally ignore excess speed less than 10mph on motorway/dual carriageways in the UK anyway, which is why most traffic on those roads is doing 80mph. At 17:13 05 October 2016, Don Johnstone wrote: At 14:59 05 October 2016, Charlie M. UH & 002 owner/pilot wrote: I've wondered if adding a small (1/4" - 3/8") anti sway bar to th trailer axle would help in most situations. Granted, proper weight is best, bu the anti sway bar may widen the margin. Thoughts? Weighting is important, no doubt. Reducing the weight and therefore th inertia on the anchored end of the trailer does reduce the possibility o any swing increasing by increasing the ability of the towing vehicle t damp the oscillations. The trigger for these oscillations is aerodynami caused by the low pressure area between two vehicles as they overtake/ar overtaken. The situation is made worse if the vertical surface is the sam or more than the area in front of the axle. Cobras and Komets are designe to reduce the side area behind the axle. I towed a trailer, containing a Grob 103 back from Holland. The nos weigh was close to the maximum limit allowed for my car, theoretically the bes situation to improve stability, however it swayed readily. I have jus towed the same combination over 300miles. Before leaving I increased th tyre pressures on the trailer from 35psi to 55psi (Max 65psi). The traile now tows with no swaying up to the maximum speed limit in the UK (70mph) It does allow towing at just below 60mph which means I can avoid bein overtaken by large trucks, the condition which is most likely to trigge swaying. Tyre pressure appears to have a large influence on the stabilit of the trailer, greater than loading. Vertical instability is now th majo problem, easily fixed by a stabiliser. |
Charlie M. (UH & 002 owner/pilot) wrote on 10/5/2016 7:59 AM:
I've wondered if adding a small (1/4" - 3/8") anti sway bar to the trailer axle would help in most situations. Granted, proper weight is best, but the anti sway bar may widen the margin. Thoughts? It's unlikely it will change the dynamics of a single axle trailer. Ante-sway bars are used on cars and similar to change the roll stiffness about each axle: generally, an anti-sway bar on the front axle increases "understeer" and makes the vehicle more stable. A rear bar does the opposite. The place to change anti-sway bars is on the tow vehicle. I suspect a bigger front bar would increase the towing stability, but I think it's better to get the trailer balance and tire pressures right (ditto for the tow vehicles tire pressures). -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Monday, October 10, 2016 at 9:53:59 PM UTC-7, Eric Greenwell wrote:
Charlie M. (UH & 002 owner/pilot) wrote on 10/5/2016 7:59 AM: I've wondered if adding a small (1/4" - 3/8") anti sway bar to the trailer axle would help in most situations. Granted, proper weight is best, but the anti sway bar may widen the margin. Thoughts? It's unlikely it will change the dynamics of a single axle trailer. Ante-sway bars are used on cars and similar to change the roll stiffness about each axle: generally, an anti-sway bar on the front axle increases "understeer" and makes the vehicle more stable. A rear bar does the opposite. The place to change anti-sway bars is on the tow vehicle. I suspect a bigger front bar would increase the towing stability, but I think it's better to get the trailer balance and tire pressures right (ditto for the tow vehicles tire pressures). -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf The most stable trailer configuration is a semi where about half the trailer weight is on the tongue. This is not possible for autos which can't support that kind of tongue weight. Even fifth wheels don't put the trailer wheels in that position, and they are accepted to be the most stable trailer configuration. I have come to realize that there are two moment of inertia of interest; one referenced to the trailer axle and the other referenced to the hitch. Why is MOI important? The answer is if you have an oscillating body it will be harder to stop the larger the MOI. This is why engines have flywheels. If you want to minimize axle MOI you would put as much weight as possible near the axle, which may decrease tongue weight. If you want to minimize hitch MOI you move weight forward, which increases axle MOI. Clearly there is something contradictory about these two MOIs. All trailer towing guides I have seen emphasize maintaining a tongue weight that is 7 to 10% of the total trailer weight. Remember that MOI is calculated as the sum of the weight times the radius SQUARED, so any weight is a long distance from the reference point has a major influence on MOI. If the trailer's tires are maintaining traction with the road the axle MOI is of interest, but if the tires loose traction then the hitch MOI dominates. For certain, putting weight at the rear of the trailer aggravates both MOIs, but increases the hitch MOI four times as much as the axle MOI. The moral of the story is to manage the hitch weight properly. Merely adding weight to the front of the trailer is not the solution: you should adjust the axle position to get the proper tongue weight. I have done this on one trailer and experimented with trailer transient response as a function of tongue weight. More tongue weight was better. Tom |
Not adding anything to the conversation, but I had purchased a Nimbus 4 that had a Pfister (spelling?) tube trailer. The tongue weight was so heavy it could only be moved by a jack. Soon after getting the bird I purchased a double axle Cobra trailer for the glider and sold the other trailer. The new cobra had a tongue weight much less than the former trailer and could be moved by hand and towed marvelously. Of course back then I was towing with a 2500 chevy Suburban and I had to put a post it on the dash to remind me that I was towing a trailer. While not an expert in any field of this particular discussion, it seems tow vehicle has much to do with the stability as the trailer. My ASw-24 towed towed great behind my little four banger Toyota pick up and horrible behind my next car a Jeep Grand Cherokee. The Suburban was my favorite tow vehicle but I had to keep reminding myself of the trailer. I am currently towing an ASG-29E with a ML 350 diesel and it tows great, but I do have a double exile trailer.
Trailer weight distribution demonstration | bumper[_4_] | Soaring | 0 | October 5th 16 07:54 AM |
weight of an Eberle trailer | raymond herr | Soaring | 3 | November 27th 11 06:20 PM |
Trailer Weight | rlovinggood | Soaring | 8 | November 1st 07 12:22 AM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
