airworthiness certificate
Old February 5th 17, 02:01 AM posted to rec.aviation.soaring
Del Jensen
Default airworthiness certificate
I am shopping for a glider. Today I looked at a 304 That is in very good shape, current on its annual. The type is experimental. The certificate in the cockpit stipulates that the glider is to be operated from a single airfield. Is this normal? Will faa hassle me were I to purchase and register it and wish to fly out of a different field? Do airworthiness certificates typically specify that an aircraft only fly out of one location?
Many thanks for any enlightenment.
FAA Revoking Standard Airworthiness Certificate DG-505 NG Soaring 32 February 16th 17 02:23 PM
Export certificate of airworthiness Greg Arnold[_2_] Soaring 2 December 27th 10 06:10 AM
Airworthiness Certificate Replacement? [email protected] Soaring 6 June 26th 08 07:11 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
Exhibition/Racing Airworthiness Certificate Question bsquared Soaring 5 June 22nd 04 06:24 PM
