Transporting water to glider
Old April 29th 04, 02:35 AM
Kilo Charlie
Like Mike I'm also in Arizona. I have tried most of the methods and find
the one that I currently use by far the best. That is a 60 gallon plastic
tank that stands without supports with a bilge pump secured inside the
bottom of it. It takes about half an hour to place the bilge pump and
proper external hose fittings. Then all you need to do is to fill the tank,
connect the pump to a cigaretter lighter and begin filling the wings. If
you need more details I'm be happy to answer them here or via private
e-mail.
Casey Lenox
KC
Phoenix
Old April 29th 04, 02:37 AM
Kilo Charlie
e-mail.
Casey Lenox
KC
Phoenix
Kilo Charlie
e-mail.
Casey Lenox
KC
Phoenix
Old April 29th 04, 05:04 AM
Kilo Charlie
Geez do I look like a geek....I swear that my ISP (Cox
Communications...sometimes appropriately named) has had server "issues" as
they try to rid us of spam. Hopefully this one won't be sent 3 times as
well!
Casey
Old April 29th 04, 12:47 PM
Jack Wyman
The Diana trailer has a built-in water tank in its roof. Very clever.
And the best part of the trailer is that it contains a Diana
sailplane. Otherwise, I've found an air mattress works just fine. And,
as has been said, it collapses and almost disappears when not in use.
Jack Wyman
Michigan (Is it spring yet?)
Old April 29th 04, 11:00 PM
Mike Lindsay
In article G1Vjc.39485$cF6.1713298@attbi_s04, Bill Daniels
writes
I Googled r.a.s and found posts about water beds, truck inner tubes and
collapsible plastic cubes from Wal-Mart. The plastic cubes will transport
50 gallons and fit inside my Jeep Grand Cherokee but nothing else will fit
and I don't want to unload the Jeep just for this chore. Full 10 gallon
water containers weigh more than 90 pounds and I don't like lifting that
much to pour it into the wing. I don't like water beds and inner tubes
either.
So, bright r.a.s people, how do you neatly and easily transport ballast
water to the glider if the gliderport doesn't have a tanker or water hoses
on the ramp? Once you get it there, how do you get it into the glider?
Bill Daniels
25 litre plastic drums. I can carry 4 of these in the back of my Volvo.
We have a hand pump, but its a difficult messy job, so I built a stand
for a BIG funnel which we can connect to the water ports on out DG202.
Haven't had a chance to try it yet.
Mike Lindsay
Old May 1st 04, 10:55 PM
Ian Forbes
ballast water to the glider if the gliderport doesn't have a tanker or
water hoses
glider?
What infrastructure does your gliderport have? If there is not a tap
close enough at your local site, can you bribe the management to get
one installed? Get the other single seater pilots to contribute to the
costs.
I always carry a long (about 40m) 1/2" diameter garden hose in the
trailer and a collection of tap fittings (about 6) of different sizes.
Then I tow the glider with the one man reverse tow kit as close as I can
to a tap, select the required tap fitting, unwind the hose pipe and
"full it up". Winding up the hose afterwards is the biggest job. (It is
good manners to move the glider away from the tap ASAP when you tanked
up, as you are probably in somebody's way - usually the pilot in the
queue behind you).
When I had the Nimbus II I put the hose straight into the ballast tank
opening on the top of the wing. You have to full the wing supported
with the wing wheel first. I used a stop watch to time the fulling time
to get an estimate of how much water had gone in. This helps to get the
same amount of water in each wing. (But it was not a problem taking off
if the balance was not perfect).
Another approach is to full the tanks 'till they overflow, then dump
water for a timed release to get down to the required loading. This can
be done during tow or after release if your situation allows you to
take off with full tanks.
Just make sure you can't pressurise the wing tank. This will cause
expensive damage, very quickly. Putting a 3/4" hose into a S-H filling
port might not leave enough room for the overflow to get out fast
enough if you forget to stop the hose. A 1/2" hose is safe.
Now I fly an LS3. (Easier on the back) But is has bags not tanks, so I
use a funnel with a hose sized to plug into the dump vent on the bottom
of the wing. The funnel has a stand which holds it about 300mm above
hight of the cockpit. I put the garden hose into the top of the funnel.
The main function of this kit is to protect the wing from over
pressure. With the LS3 I have to hold the heavy wing in the air when I
start fulling the 2nd wing. In theory you need two people for this. I
can do it on my own - but it splashes a little. I don't bother to suck
the air out of the bags before filling, and I never quite get them 100%
full but that does not matter - I get enough water in to reach my
desired wing loading.
Keep your filling kit simple. The faster you get the water in, the
sooner you can launch and the more distance you can cover in the day.
Also, the easier it is to full the glider, the more often you will use
water and the better your "flying with water" skills will become. If
you only use water on those very special days, you won't be ready to
extract maximum advantage from the extra wing loading.
I usually take off with more water than the conditions warrent and dump
some when airborne.
Test dump a full load of water on the ground while watching carefully
and timing with a stop watch. Then you know how many seconds it takes
to dump all the water, and you get an idea how "linear" the dump rate
is by watching the outflow. Also note if both tanks dump at the same
rate - if there is a big discrepancy the dump valves may need
maintenance. Then count seconds while dumping in the air so as to have
an idea how much water is in board.
It may be worth doing one full from known capacity containers. Then you
can establish how much water you tanks can actually hold and confirm if
they both hold the same volume.
Ian
PS: The Nimbus II flies best when the water overflowing from the filler
valves and freezes into an icicle on the top surface of the wing -
because it's sitting at 18000' :-)
Old May 2nd 04, 12:11 AM
Bill Daniels
Ian, thank you very much for the detailed post. Was your Nimbus a 2C? My
2C wing tanks hold 140 Kg/liters each.
Bill Daniels
"Ian Forbes" wrote in message
water hoses
glider?
costs.
queue behind you).
some when airborne.
Ian
Old May 2nd 04, 04:52 PM
Papa3
What's the prejudice against inner tubes? I assembled a highly reliable
system for less than $15 bucks consisting of the following:
- Inner tube with damaged valve stem: Free from local tire store.
- Thu-hull connector (Vinyl pipe with threaded flange): $5 from local
marine supply.
- Brass water connections (garden hose repair kit): $4 from local hardware
store
- 25 feet of garden hose: $5 at garage sale
- Filling the glider and hot showers at the field to boot: Priceless
In all seriousness, the tube is highly rugged and portable - it rolls up to
fit inside my washing bucket. I've used it for about 8 seasons now with no
leaks. Depending on which of many sizes you select, you can get capacities
from about 10 gallons on up to ... enough to crush the roof of your car
(volume calculator he
http://grapevine.abe.msstate.edu/~ft...vol/torus.html ). Don't
underestimate the shower aspect either. The black tube sitting on the car
roof all day provides water at about 85 degrees F. This is just about the
perfect temperature for a warm shower on a summer day!
I also use a brass water-meter designed for measuring garden use. This is
expensive, but it allows you to be confident of your weight, especially
important at contests. The one I have came from... where else..
http://water.meters.com The specific model is:
http://www.jerman.com/hosemeter.html
"Bill Daniels" wrote in message
news:G1Vjc.39485$cF6.1713298@attbi_s04...
either.
Bill Daniels
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
I wish I'd never got into this... Kevin Neave Soaring 32 September 19th 03 12:18 PM
