#11
then go tell my insurance company that I am wrong... if it doesn't have an
FAA document (certification) in the "aircraft" that says it's a "glider".. I'm not towing it. It's an ultralight, and FAR91.311 says I can only tow according to 91.309, and 91.309 says "glider", I can't tow ultralights. BT "ADP" wrote in message ... It is always fascinating to me how people make up or interpret regulations to fit their preconceived notions. 14 CFR 1 Definitions: "Glider means a heavier-than-air aircraft, that is supported in flight by the dynamic reaction of the air against its lifting surfaces and whose free flight does not depend principally on an engine." It seems to me that any vehicle capable of carrying a person, regardless of weight, that uses gravity as its principle means of staying aloft, meets the definition of a glider. I see no regulation that requires certification or that an ultralight can not also be a glider. The original intent of the FARs was to be permissive rather than restrictive. Thus, if it is not specifically prohibited, it can be presumed, within reason, to be permitted. So, Eric is right and Btiz is wrong. Allan "Eric Greenwell" wrote in message BITZ so would their policy be in force if an FAR is violated? I can't find where the regulations says an aircraft has to be certified to be a glider. What is the CFR number for that? I mean, clearly it's a glider, or is there a CFR that requires an aircraft to weight over 155 pounds before it's can qualify as a glider? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Brian... read 91.311, it says you can't tow ANYTHING (banners, whatever)
without a waiver, except as outlined in 91.309. 91.309 is the "glider tow" endorsement. Our insurance carrier has made it clear that without an airworthy certification that says "glider" we are not covered. Arguments about FARs are open to debate, that's why we have lawyers. BT "Brian Case" wrote in message om... Actually it would be more reasonable to argue the other direction. I haven't looked it up but if I recall my definitions the FAA does not consider an ultralight vehical to be an Aircraft. While It may meet the definiation of a glider, if meets the definition of an ultralight the FAA does not reconginize it as an aircraft and as a result it does not need to be registered, Certified or require a Pilot Certificate to fly it. I do not recall any regulation concerning towing of ultralight vehicals so It could be argued that as far as the regulations are concerned there are no tow pilot requirements for towing ultralight vehicals. As such a newly licensed recreational Pilot might be able to Tow ultralight vehicals with no endorsements required. They would have to be careful not to be receiving any compensation for doing so. Just because it might be allowed by the regulations does not make it safe or reasonable to try it. Insurance wording is an entirely different matter. Brian CFIIG/ASEL First I will ask a question, Is the Sparrow Hawk registered with an N-number and does it have an Airworthiness Cert that it is a "glider" If not your club needs to re-look at it's insurance, and your tow pilots at their ratings.. They are certified to tow gliders, not any thing else, if they are towing an ultra light that is not certified by the FAA as a "glider" and has an N-number registration, they are in violation of FARs and most likely the tow plane's insurance is in violation. At that point in time it matters not if the "ultra light" has insurance or not. JMHO BT |
![]() Block A reads: "CATEGORY/PURPOSE Experimental" "PURPOSE Operating Amateur-Built Aircraft (Glider) A typewriter was used to enter the data on the certificate. Maybe the entries are not as standardized as we would assume. Wayne http://www.soaridaho.com/Schreder Yeah, maybe not very standardized - but the word glider is there. The Order also says if it's a balloon, it should have the word Balloon in parentheses - apparently this annotation of type on the Special Airworthiness Certificate is to help the FAA to know that no medical is needed (!!??) - at least that's what it says in the Order. There will certainly be differences between Special Airworthiness Certificates typed up before 1993 and after 1993 - quite a change in the guidance that year. On another note, I saw a notice in the Federal Register last Friday - actually a Final Rule - that says if one does not print or type one's name on the temporary registration certificate as required by the rule, instructions, order, guidance, etc. - then the registration certificate will not be processed and then one would be in a heap o' trouble. It appears one must sign the form with your signature AND print or type your name on the form. Hard to believe they had to go to the Federal Register on this one!! If you get bored with RAS, you can always read the FR for fun, or maybe load up Dr. Jacks and pray for a change in the forecast. If you really want to have some fun, go find the FAR Preambles on the web and read the true meaning of towing an ultralight, it's kinda fun - but very difficult to find. Back to sanding wing tips now... Jim |
further review of Part 103 was recommended.. So I read the entire 3 pages.
I only see two types of Ultralights.. Powered and Unpowered, and no where anywhere in Part 103 did I find a reference to an "Ultralight glider" So... if operating under Part 103, it's an ultralight and gives way to all aircraft. If you want to be called a glider, then I'm thinking you want to operate under Part 91 which means you need an airworthiness certificate. And Part 91.309 says I can only tow "glider" , not an unpowered ultra light. That would fall into that other category under 91.311. Also, there is no definition for "ultralight" in FAR 1.1, that definition only exists in Part 103 Part 103 also says no pilot certification to fly an "ultralight" is required, so how can I properly assess that any "pilot" that shows up with an "ultra light" can actually fly it. I've always liked the design of the Sparrowhawk and would love to have one. If and when I do, I'll take the extra time to get the certifications to fly under Part 91. BT "BTIZ" wrote in message news:_rgmc.12051$k24.7723@fed1read01... Brian... read 91.311, it says you can't tow ANYTHING (banners, whatever) without a waiver, except as outlined in 91.309. 91.309 is the "glider tow" endorsement. Our insurance carrier has made it clear that without an airworthy certification that says "glider" we are not covered. Arguments about FARs are open to debate, that's why we have lawyers. BT "Brian Case" wrote in message om... Actually it would be more reasonable to argue the other direction. I haven't looked it up but if I recall my definitions the FAA does not consider an ultralight vehical to be an Aircraft. While It may meet the definiation of a glider, if meets the definition of an ultralight the FAA does not reconginize it as an aircraft and as a result it does not need to be registered, Certified or require a Pilot Certificate to fly it. I do not recall any regulation concerning towing of ultralight vehicals so It could be argued that as far as the regulations are concerned there are no tow pilot requirements for towing ultralight vehicals. As such a newly licensed recreational Pilot might be able to Tow ultralight vehicals with no endorsements required. They would have to be careful not to be receiving any compensation for doing so. Just because it might be allowed by the regulations does not make it safe or reasonable to try it. Insurance wording is an entirely different matter. Brian CFIIG/ASEL First I will ask a question, Is the Sparrow Hawk registered with an N-number and does it have an Airworthiness Cert that it is a "glider" If not your club needs to re-look at it's insurance, and your tow pilots at their ratings.. They are certified to tow gliders, not any thing else, if they are towing an ultra light that is not certified by the FAA as a "glider" and has an N-number registration, they are in violation of FARs and most likely the tow plane's insurance is in violation. At that point in time it matters not if the "ultra light" has insurance or not. JMHO BT |
what Jim... no links?
BT "Jim Phoenix" wrote in message ... Block A reads: "CATEGORY/PURPOSE Experimental" "PURPOSE Operating Amateur-Built Aircraft (Glider) A typewriter was used to enter the data on the certificate. Maybe the entries are not as standardized as we would assume. Wayne http://www.soaridaho.com/Schreder Yeah, maybe not very standardized - but the word glider is there. The Order also says if it's a balloon, it should have the word Balloon in parentheses - apparently this annotation of type on the Special Airworthiness Certificate is to help the FAA to know that no medical is needed (!!??) - at least that's what it says in the Order. There will certainly be differences between Special Airworthiness Certificates typed up before 1993 and after 1993 - quite a change in the guidance that year. On another note, I saw a notice in the Federal Register last Friday - actually a Final Rule - that says if one does not print or type one's name on the temporary registration certificate as required by the rule, instructions, order, guidance, etc. - then the registration certificate will not be processed and then one would be in a heap o' trouble. It appears one must sign the form with your signature AND print or type your name on the form. Hard to believe they had to go to the Federal Register on this one!! If you get bored with RAS, you can always read the FR for fun, or maybe load up Dr. Jacks and pray for a change in the forecast. If you really want to have some fun, go find the FAR Preambles on the web and read the true meaning of towing an ultralight, it's kinda fun - but very difficult to find. Back to sanding wing tips now... Jim |
![]() "BTIZ" wrote in message news:frhmc.12063$k24.9961@fed1read01... what Jim... no links? Jeez... I didn't think anyone was really interested in reading this stuff! Just google GPO for the Federal Register, and you can get the 8130.2E at faa.gov. Jim |
well... Jim.. I meant the ultralight tow issue..
whatwhichwhose wing tips? BT "Jim Phoenix" wrote in message ... "BTIZ" wrote in message news:frhmc.12063$k24.9961@fed1read01... what Jim... no links? Jeez... I didn't think anyone was really interested in reading this stuff! Just google GPO for the Federal Register, and you can get the 8130.2E at faa.gov. Jim |
consider an ultralight vehical to be an Aircraft. While It may meet the definiation of a glider, if meets the definition of an ultralight the FAA does not reconginize it as an aircraft and as a result it does not need to be registered, Certified or require a Pilot Certificate to fly it. On the contrary, there is absolutely nothing in Part 103 saying that an ultralight vehicle is not an aircraft. It is one, in accordance with the definition of an Aircraft in 14 CFR Part 1.1. Part 103 exempts ultralight vehicles from the requirements that would otherwise apply to aircraft under 14 CFR. For example, "Notwithstanding any other section pertaining to certification of aircraft or their parts or equipment, ultralight vehicles and their component parts and equipment are not required to meet the airworthiness certification standards specified for aircraft or to have certificates of airworthiness." Note that it does not suggest that ultralight vehicles are not aircraft, it merely exempts them from the standards and requirement for certificates of airworthiness. It could be argued that as far as the regulations are concerned there are no tow pilot requirements for towing ultralight vehicals. As such a newly licensed recreational Pilot might be able to Tow ultralight vehicals with no endorsements required. Again, on the contrary, 14 CFR 91.311 requires an exemption to use an aircraft to tow anything other than a glider, and a glider can only be towed subject to the relevant requirements. It does seem to me that the FAA wanted to stay away from having anything to do with ultralight vehicles, and probably didn't have in mind the possibility that one might be towed by a certificated aircraft. So certainly if substantial amounts of common sense aren't applied by pilots themselves and people start towing hang gliders with Pawnees, the FAA is likely to feel compelled to step in. Hang glider pilots, in general, seem to have a fair understanding of what would happen to a flexwing towed at 70 knots, and Pawnee pilots probably have enough common sense not to try it, but then again to paraphrase someone or other, no-one ever got rich by over-estimating the intelligence of the public... And Jim Phoenix is right: there IS a requirement that an Experimental glider should have (Glider) in the Category/Designation block. The reason, oddly, is to "ensure appropriate application of 14 CFR Part 61 .... concerning the medical requirements for the operation of such aircraft." |
"BTIZ" wrote in message news:Uhhmc.12061
Also, there is no definition for "ultralight" in FAR 1.1, that definition only exists in Part 103 The definitions in 14 CFR Part 1.1 cover Part 103. |
![]() It could be argued that as far as the regulations are concerned there are no tow pilot requirements for towing ultralight vehicals. As such a newly licensed recreational Pilot might be able to Tow ultralight vehicals with no endorsements required. Again, on the contrary, 14 CFR 91.311 requires an exemption to use an aircraft to tow anything other than a glider, and a glider can only be towed subject to the relevant requirements. It looks like the USHGA has an exemption No. 4144 from the FAA that covers the towing of unpowered ultralight aircraft by powered ultralight aircraft where both aircraft would be operating under part 103 There are a lot of requirements spelled out under the USHGA rules part 104 that cover required pilot training and also related to equipment and which the exemption requires be met. See: http://www.ushga.org/104-part-2.asp#4144 The case where a towplane operating under part 61 and 91 would be towing an unpowered ultralight that was not registered, and therefore operating under part 103, would appear to have been not accounted for under either part 103 or part 61 and 91 and likely appears to be not allowed without another waiver, at least on the part of the towplane operating under part 61 and 91. It does seem to me that the FAA wanted to stay away from having anything to do with ultralight vehicles, and probably didn't have in mind the possibility that one might be towed by a certificated aircraft. So certainly if substantial amounts of common sense aren't applied by pilots themselves and people start towing hang gliders with Pawnees, the FAA is likely to feel compelled to step in. Hang glider pilots, in general, seem to have a fair understanding of what would happen to a flexwing towed at 70 knots, and Pawnee pilots probably have enough common sense not to try it, but then again to paraphrase someone or other, no-one ever got rich by over-estimating the intelligence of the public... This is almost exactly what they say in U.S. DOT FAA Advisory Circular 103-7 see http://www.ultralighthomepage.com/AC103-7/ac103-7.html They mainly care about protecting the non-flying public, and other members of the flying public using the same airspace, but: "Part 103 is based on the assumption that any individual who elects to fly an ultralight vehicle has assessed the dangers involved and assumes personal responsibility for his/her safety." " e. You are Responsible for the Future Direction the Federal Government Takes With Respect to Ultralight Vehicles, The actions of the ultralight community will affect the direction Government takes in future regulations. The safety record of ultralight vehicles will be the foremost factor in determining the need for further regulations." |
Six aboard USS Kitty Hawk injured in F/A 18 landing accident | Otis Willie | Naval Aviation | 0 | January 31st 05 10:50 PM |
Black Hawk unit pays tribute to aviators | Otis Willie | Military Aviation | 0 | June 26th 04 10:31 PM |
Did the MoD waste GBP 800 million on Hawk trainers? | phil hunt | Military Aviation | 6 | December 11th 03 04:37 AM |
Black Hawk crash-lands near Taegu | Otis Willie | Military Aviation | 0 | August 8th 03 10:47 PM |
Arming Global Hawk Draws Conflicting Comments From Pentagon | Larry Dighera | Military Aviation | 5 | July 14th 03 08:51 PM |
