I have my new Sparrow Hawk
Old May 5th 04, 01:40 AM
Patrick McLaughlin
Default I have my new Sparrow Hawk
I recived my Sparrow Hawk SN #10 just two weekends ago. I was the test
pilot for the virgin bird. After 2.5 Hrs. in light 'high-pressure day'
thermals in Central Oregon. All I needed to adjust was the rudder
peddle lenght. Greg Cole said I main a record for the most time aloft
with the least number of tows. @ tows and ~ 5.5 Hrs.
I was able to walk the glider out to the runway by mayself, at 155 lbs
& wheels, why not, hook-up and go. The tow, flight and landing is very
easy. Controls are very responsive and light, but not the least bit
twitchy. In otherwards, no over sensitive pitching as with many other
gliders.
I have been flying a Nimbus-II till the Sparrow hawk came around.
Although one is a mere 155 Lbs, while the other is well over 1,000
lbs. I found that transitining from one to the other was a non issue.
I have been flying powered aircraft and hang gliders sence 1972. It is
my honest openion that any one who has been flying moderate to high
performance flex wings and rigid wings will fell very much at home
with the Sparrow Hawk.
One would think that such a light glider would blow about like a paper
bag and have potentual penitration problems. Not so, Creg Cole has
designed airfoils specifically for this light weight application. What
with wing-loading similar to any other standard class glider it feels
very solid and secure, even in big air. Its like a solid high
performance sports car. I can thermal, much like my hang glider, as
tight as I desire, taking advantage of small light, scratchy thermals.
Many that I would simply pass up in many other sail planes. I hope to
travel about with it to many other sites.
Towing:
Our glider club said that as long as a Sparrow Hawk owner is a current
local club and SSA member, there will be no problems getting a tow and
have insurance cover the tow plane, but not the glider. We have a
Piper Pawnee. I am sure that the insurance situation will be the same
with many other clubs and comercial operations.
I will be flying my Sparrow Hawk glider much more real soon and hope
to answer any questions one may have.
Old May 5th 04, 03:42 AM
BTIZ
"Patrick McLaughlin" wrote in message
om...
Towing:
First I will ask a question, Is the Sparrow Hawk registered with an N-number
and does it have an Airworthiness Cert that it is a "glider"
If not your club needs to re-look at it's insurance, and your tow pilots at
their ratings.. They are certified to tow gliders, not any thing else, if
they are towing an ultra light that is not certified by the FAA as a
"glider" and has an N-number registration, they are in violation of FARs and
most likely the tow plane's insurance is in violation. At that point in time
it matters not if the "ultra light" has insurance or not.
JMHO
BT
Old May 5th 04, 05:10 AM
BTIZ
also, most "Club" insurance policies cover the tow plane and the clubs
gliders, but not private owners gliders... so their statement is moot.. they
would be covered but you are not, unless their error causes your damage...
towing an "aircraft", not certified as a "glider" and not registered with an
N-number, violates FAR 91.311, do you have a waiver to tow an non registered
ultra light?
so would their policy be in force if an FAR is violated?
BT
"BTIZ" wrote in message
news:iwYlc.11873$k24.11221@fed1read01...
om...
Towing:
N-number
at
and
time
JMHO
BT
Old May 5th 04, 06:35 AM
Eric Greenwell
ultra light?
I can't find where the regulations says an aircraft has to be certified
to be a glider. What is the CFR number for that? I mean, clearly it's a
glider, or is there a CFR that requires an aircraft to weight over 155
pounds before it's can qualify as a glider?
Eric Greenwell
Washington State
USA
Old May 5th 04, 07:34 AM
ADP
It is always fascinating to me how people make up or interpret regulations
to fit their preconceived notions.
14 CFR 1 Definitions:
"Glider means a heavier-than-air aircraft, that is supported in flight by
dynamic reaction of the air against its lifting surfaces and whose free
flight does not depend principally on an engine."
It seems to me that any vehicle capable of carrying a person, regardless of
weight,
that uses gravity as its principle means of staying aloft, meets the
definition of
a glider. I see no regulation that requires certification or that an
ultralight can
not also be a glider.
The original intent of the FARs was to be permissive rather than
restrictive.
Thus, if it is not specifically prohibited, it can be presumed, within
reason,
to be permitted.
So, Eric is right and Btiz is wrong.
Allan
BITZ
I can't find where the regulations says an aircraft has to be certified to
Eric Greenwell
Washington State
USA
Old May 6th 04, 02:17 AM
BTIZ
then go tell my insurance company that I am wrong... if it doesn't have an
FAA document (certification) in the "aircraft" that says it's a "glider"..
I'm not towing it. It's an ultralight, and FAR91.311 says I can only tow
according to 91.309, and 91.309 says "glider", I can't tow ultralights.
BT
"ADP" wrote in message
of
weight,
definition of
ultralight can
restrictive.
reason,
to be permitted.
Allan
BITZ
to
Eric Greenwell
Washington State
USA
Old May 5th 04, 07:35 AM
Finbar
14 CFR § 1.1 General definitions.
Aircraft means a device that is used or intended to be used for flight
in the air.
by the dynamic reaction of the air against its lifting surfaces and
whose free flight does not depend principally on an engine.
The Federal Aviation Regulations do not limit the definition of a
Glider to an aircraft operated solely under Part 91, 121 and/or 135:
it may be operated under Part 103 and still be a Glider. Aircraft
operated under Part 103 do not require Airworthiness Certificates.
While an insurance policy may have requirements that the towed vehicle
have an Airworthiness Certificate, the FAA does not require one in
order to consider the vehicle a "Glider."
Also, the Airworthiness Certificate issued for the vehicle I regularly
fly does not anywhere describe it as a Glider, or as anything else.
There isn't even a box on the certificate where one would enter that
kind of information.
Old May 6th 04, 03:14 AM
Jim Phoenix
Block A reads: "CATEGORY/PURPOSE Experimental"
"PURPOSE Operating Amateur-Built Aircraft (Glider)
A typewriter was used to enter the data on the certificate. Maybe the
entries are not as standardized as we would assume.
http://www.soaridaho.com/Schreder
Yeah, maybe not very standardized - but the word glider is there. The Order
also says if it's a balloon, it should have the word Balloon in
parentheses - apparently this annotation of type on the Special
Airworthiness Certificate is to help the FAA to know that no medical is
needed (!!??) - at least that's what it says in the Order. There will
certainly be differences between Special Airworthiness Certificates typed up
before 1993 and after 1993 - quite a change in the guidance that year.
On another note, I saw a notice in the Federal Register last Friday -
actually a Final Rule - that says if one does not print or type one's name
on the temporary registration certificate as required by the rule,
instructions, order, guidance, etc. - then the registration certificate will
not be processed and then one would be in a heap o' trouble. It appears one
must sign the form with your signature AND print or type your name on the
form.
Hard to believe they had to go to the Federal Register on this one!! If you
get bored with RAS, you can always read the FR for fun, or maybe load up Dr.
Jacks and pray for a change in the forecast. If you really want to have some
fun, go find the FAR Preambles on the web and read the true meaning of
towing an ultralight, it's kinda fun - but very difficult to find.
Back to sanding wing tips now...
Six aboard USS Kitty Hawk injured in F/A 18 landing accident Otis Willie Naval Aviation 0 January 31st 05 10:50 PM
Black Hawk unit pays tribute to aviators Otis Willie Military Aviation 0 June 26th 04 10:31 PM
Did the MoD waste GBP 800 million on Hawk trainers? phil hunt Military Aviation 6 December 11th 03 04:37 AM
Black Hawk crash-lands near Taegu Otis Willie Military Aviation 0 August 8th 03 10:47 PM
Arming Global Hawk Draws Conflicting Comments From Pentagon Larry Dighera Military Aviation 5 July 14th 03 08:51 PM
