302 Problem
Old August 17th 04, 06:27 PM
Hal
(Wiktor Kozlik) wrote in message . com...
I tried a few of the suggestions but no luck, it was Friday the 13th.
Tommorrow I will try doing it with the PC but I think it is some kind
of lapse in the 302. I had a nice flight and I will be happy with
that.
I had exactly the same problem yesterday during the contest in Uvalde.
In my case, the download would stop after 57 blocks out of 227.
Luckily there were people on the site that knew what to do. I needed
to upgrade the 302 to the latest firmware available from
www.cambridge-aero.com. That fixed the problem. The upgrade utility
for iPaq did not work for me, so I had to do the upgrade from my
laptop through a serial cable.
Wiktor
Wiktor is correct. I went to the web site and reloaded the 302. The
flight was transferred correctly after that. I don't think it matters
whether you use a pc or pda but you do need the current software!
Old August 16th 04, 05:43 PM
Thomas F. Dixon
Had this same problem at the Ephrata contest. I use an AERO pda and
download the files to a chip. The chip was full. Had not removed a
flight in three years. Removed all my flights from 2001 and
everything worked fine.
Tom
Idaho
(Hal) wrote in message . com...
Has anyone had problems with the 302 transferring only part of a
flight. It reports finished after transferring 101 of xxx blocks. I
use Winpilot connected to the 302. I can't recall any problems during
thr flight.
Have not had this problem before and of course it happened on my first
sucessful 500k flight.
GEM 1200 Problem Jim Kaufeld Owning 11 March 22nd 04 03:54 AM
A problem in the Military ? Nick Jade Military Aviation 54 March 15th 04 07:59 PM
Garmin fixes moving waypoint problem -- almost Jon Woellhaf Instrument Flight Rules 6 November 28th 03 05:29 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
