Why the T-Tail?
Old October 26th 04, 05:21 PM
Peter Seddon
"Derrick Steed" wrote in message
What about the pilatus B4 then?
Rgds,
Derrick Steed
Whats your point the B4 is a T Tail, I fly one
Peter.
Old October 26th 04, 05:22 PM
Peter Seddon
"Peter Seddon" wrote in message
Rgds,
Derrick Steed
Peter.
Oh you mean modern, well it is of sorts.
Peter.
Old October 26th 04, 05:28 PM
Peter Seddon
"Jim Vincent" wrote in message
It has a T-tail too;-)
Seriously, every design is a trade off between structural weight and
performance issues such as wetted area and configuration.
The B-4 is an aerobatic glider with very good glider performance, about
35:1.
It has a shorter distance from wing to tail compared to most gliders and a
larger cross section. That allows the structure to handle the torsional
forced
induced by the T-tail. In fact there are two models, one for limited
aerobatics, the other for full. The main difference is a stiffening plate
at
the tail.
Jim Vincent
N483SZ
illspam
There are actually 3 variants 4 if you count the fixed U/C one
they are
B4 PC11
B4 PC11A
B4 PC11AF
Peter.
Old October 26th 04, 07:13 PM
Jim Vincent
they are
B4 PC11
B4 PC11A
B4 PC11AF
Peter.
Hey Peter...I missed that! I never knew there was a fixed gear version.
I had a B4 for a few years and I think it was the best metal work I've ever
seen.
Come to think of it, I once saw a yellow one and a white one, so that makes it
five ;-)
Jim Vincent
N483SZ
illspam
Old October 26th 04, 10:31 PM
Derrick Steed
Someone implied that aerobatic gliders don't have T tails.
Rgds,
Derrick Steed
Old October 26th 04, 11:39 PM
Shawn
Marian Aldenhövel wrote:
Hi,
I have noticed that most if not all modern gliders are built with a
T-Tail (not sure about the term, I am talking about the elevator being
located at the top of the tailfin). While most power-aircraft I know
right up to the airliners have it at the bottom.
What are the aerodynamic or constructive reasons for that?
Aerodynamics, Ha! It looks cool. That's what sells gliders.
Shawn
Old October 26th 04, 11:48 PM
Stefan
It was me. I wrote: Any *serious* aerobatic plane ... etc. The point is,
the B4 was *not* designed as an acro glider. Only later they found that
due to it's superior handling it would make an ideal acro glider. The
structure had to be reinforced, though, to allow flick maneuvres ...
exactly because of the huge torque forces caused by the T-tail.
BTW: There are many gliders which are certificated for some acro
figures: ASK-21, DG-500, DG-1000 just to name a few. All of them have
T-tail, none of them is primarily an acro glider, all are cross country
gliders which just happen to be allowed for some simple acro figures,
and, you guessed it, none of them is certificated for flick maneuvres.
Stefan
Old October 27th 04, 12:02 AM
Marc Ramsey
The flight manual for my T-tailed DG-303 Acro allowed flick maneuvers
and tail slides...
Marc
Old October 27th 04, 12:41 AM
Stefan
and tail slides...
Lucky you. Lucky me that I didn't explicitely mention the DG-300.
Seriously, I only wanted to say that all airplanes which are primarily
designed for serious, competitive aerobatics have a "conventional" tail.
All which I know, that is. (And yes, the salto has a V-tail, which isn't
worse, torqueforcewise.)
Of course there are many airplanes with T-tail which are allowed for
aerobatics to some degree, and some might even be allowed for flick
maneuvres.
What was the question again? Ah, pros and cons of T-tail vs. conventional.
Stefan
Old October 27th 04, 12:46 AM
Jim Britton
FYI: Flick half rolls are allowed in the DG-1000 (18M).
for some acro
All of them have
are cross country
acro figures,
flick maneuvres.
Stefan
Tail Skid Help / Advice Ray Lovinggood Soaring 3 January 2nd 04 08:16 PM
AH64 tail rotor CivetOne Rotorcraft 3 October 23rd 03 07:18 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Owning 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Piloting 1 July 26th 03 11:34 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
