#11
Hi Mal,
You will probably need to do some searching to find out on which comm port the GPS data is available. I suggest you try using the free "Crux_View.exe" utility that is available on my GPS page to test for the PIN's GPS on comm ports 1 through 9. If that doesn't work it may not be possible to use the PIN's GPS. http://www.cumulus-soaring.com/gps.htm I believe pocket*StrePla cannot connect to a GPS until you install a license file. That may be the problem. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... It does not work on a Navman PIN it says the com port is already in use "jorgie" wrote in message ... You cold also consider XCSoar which is available for free. It is not as sophisicated. However, it depends of what you want. Try looking at: http://groups.yahoo.com/group/XCSoar/ -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
Hi Mal,
I can sell the upgrade to you. It is available for StrePla only, or for a "Bundle" of StrePla and pocket*StrePla. Details are available he http://www.soarmn.com/cumulus/strepla-prices.htm Thank you, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... Bundle for update customer Update to StrePla3 Standard version from version 1.xx, version 2.xx and OEM version, as described above and pocket*StrePlaź Standard version for PocketPC (e.g. iPAQ), as described above by simultaneous order EUR 237.07 My Volkslogger-Voucher-Number is: (only for Volkslogger customer) My CPU-ID is: (Please do not use the serial number. Install pocket*StrePla and read than the CPU-ID.) You save EUR 29.31 in relation to the single purchase $316.410 USD $405.327 AUD Is that voucher valid with you Paul www.mals.net |
Sorry Paul XCSoar does not work with Navman PIN the gps uses COM 2
I am sure win pilot strepla will work as the cater for Navman in the setup I am aware I have to pay hence my pain staking research. thanks Mal "Paul Remde" wrote in message news:3xKrd.502083$D%.394489@attbi_s51... Hi Mal, You will probably need to do some searching to find out on which comm port the GPS data is available. I suggest you try using the free "Crux_View.exe" utility that is available on my GPS page to test for the PIN's GPS on comm ports 1 through 9. If that doesn't work it may not be possible to use the PIN's GPS. http://www.cumulus-soaring.com/gps.htm I believe pocket*StrePla cannot connect to a GPS until you install a license file. That may be the problem. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... It does not work on a Navman PIN it says the com port is already in use "jorgie" wrote in message ... You cold also consider XCSoar which is available for free. It is not as sophisicated. However, it depends of what you want. Try looking at: http://groups.yahoo.com/group/XCSoar/ -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
Mal wrote:
Sorry Paul XCSoar does not work with Navman PIN the gps uses COM 2 Of course, since XCSoar is now an open source project, if you ask nicely, someone might fix it... Marc |
![]() Try GPS_LOG, which may seem a little complicated at first, but after getting used to is one pretty good piece of software. Contrary to XCSoar it's actively supported and developed further by Henryk Bierki. I guess it depends on your view point as to wether a product is supported or not. True it is not now developed by the orginal people who started it. However, the source code is available for free and I'm sure that somebody you know would be able to work out how to modify the code to function on the Navman I'm happy to try GPS_LOG and will do so next time I fly.... in the mean time if it can load a map image and some air space files now that would be funky. -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
jorgie wrote:
Try GPS_LOG, which may seem a little complicated at first, but after getting used to is one pretty good piece of software. Contrary to XCSoar it's actively supported and developed further by Henryk Bierki. I guess it depends on your view point as to wether a product is supported or not. True it is not now developed by the orginal people who started it. However, the source code is available for free and I'm sure that somebody you know would be able to work out how to modify the code to function on the Navman I'm happy to try GPS_LOG and will do so next time I fly.... in the mean time if it can load a map image and some air space files now that would be funky. -- jorgie Hi Henryk does a great job supporting GPS_LOG, the latest example being the DAFIFtoMAP program, which creates the airspace file of your choice based on DAFIF data. Lots of maps are already available and the web site contains the information needed to create your own maps, once again using geographical data from internet. It may look first a bit complicated, but it isn't :-). Also you get good support from the user community if you have questions. Take a look at http://www.soaringpilotsoftware.com , you can find the yahoogroups info for GPS_LOG also there. Regards Veli-Matti |
Crux view works com 2 4800 baud
maybe XCsoar will work sometimes get com port in use could be navman conflict Mal "Veli-Matti Karppinen" wrote in message ... jorgie wrote: Try GPS_LOG, which may seem a little complicated at first, but after getting used to is one pretty good piece of software. Contrary to XCSoar it's actively supported and developed further by Henryk Bierki. I guess it depends on your view point as to wether a product is supported or not. True it is not now developed by the orginal people who started it. However, the source code is available for free and I'm sure that somebody you know would be able to work out how to modify the code to function on the Navman I'm happy to try GPS_LOG and will do so next time I fly.... in the mean time if it can load a map image and some air space files now that would be funky. -- jorgie Hi Henryk does a great job supporting GPS_LOG, the latest example being the DAFIFtoMAP program, which creates the airspace file of your choice based on DAFIF data. Lots of maps are already available and the web site contains the information needed to create your own maps, once again using geographical data from internet. It may look first a bit complicated, but it isn't :-). Also you get good support from the user community if you have questions. Take a look at http://www.soaringpilotsoftware.com , you can find the yahoogroups info for GPS_LOG also there. Regards Veli-Matti |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
Small Sheriff's Departments Using Helicopters | Gig Giacona | Rotorcraft | 23 | September 7th 03 09:52 AM |
