I have purchased a Navman pin has built in Gps
Have a Volkslogger but no need to connect it to the navman pin. I will be using it in Australia what is the better of the two. Mal |
You cold also consider XCSoar which is available for free. It is not as sophisicated. However, it depends of what you want. Try looking at: http://groups.yahoo.com/group/XCSoar/ -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
It does not work on a Navman PIN it says the com port is already in use
"jorgie" wrote in message ... You cold also consider XCSoar which is available for free. It is not as sophisicated. However, it depends of what you want. Try looking at: http://groups.yahoo.com/group/XCSoar/ -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
Hi Mal,
You will probably need to do some searching to find out on which comm port the GPS data is available. I suggest you try using the free "Crux_View.exe" utility that is available on my GPS page to test for the PIN's GPS on comm ports 1 through 9. If that doesn't work it may not be possible to use the PIN's GPS. http://www.cumulus-soaring.com/gps.htm I believe pocket*StrePla cannot connect to a GPS until you install a license file. That may be the problem. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... It does not work on a Navman PIN it says the com port is already in use "jorgie" wrote in message ... You cold also consider XCSoar which is available for free. It is not as sophisicated. However, it depends of what you want. Try looking at: http://groups.yahoo.com/group/XCSoar/ -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
Sorry Paul XCSoar does not work with Navman PIN the gps uses COM 2
I am sure win pilot strepla will work as the cater for Navman in the setup I am aware I have to pay hence my pain staking research. thanks Mal "Paul Remde" wrote in message news:3xKrd.502083$D%.394489@attbi_s51... Hi Mal, You will probably need to do some searching to find out on which comm port the GPS data is available. I suggest you try using the free "Crux_View.exe" utility that is available on my GPS page to test for the PIN's GPS on comm ports 1 through 9. If that doesn't work it may not be possible to use the PIN's GPS. http://www.cumulus-soaring.com/gps.htm I believe pocket*StrePla cannot connect to a GPS until you install a license file. That may be the problem. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... It does not work on a Navman PIN it says the com port is already in use "jorgie" wrote in message ... You cold also consider XCSoar which is available for free. It is not as sophisicated. However, it depends of what you want. Try looking at: http://groups.yahoo.com/group/XCSoar/ -- jorgie ------------------------------------------------------------------------ Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ] - A website for Australian Pilots regardless of when, why, or what they fly - |
Mal wrote:
Sorry Paul XCSoar does not work with Navman PIN the gps uses COM 2 Of course, since XCSoar is now an open source project, if you ask nicely, someone might fix it... Marc |
Hi,
I sell and support StrePla. It shines in regard to maps and in-flight optimizations. WinPilot is excellent software as well. I don't sell WinPilot but I have flown with it in the past. I have not tested either product on the Navman Pin but you could install the demo versions of each product for testing. You may also want to consider SeeYou Mobile and Glide Navigator II. Those are the 4 most popular options. I have created a soaring flight software comparison web page which may help you decide. It is available he http://www.soarmn.com/cumulus/software-ppc.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... I have purchased a Navman pin has built in Gps Have a Volkslogger but no need to connect it to the navman pin. I will be using it in Australia what is the better of the two. Mal |
"Paul Remde" wrote in message news:hzcrd.118507$V41.113826@attbi_s52...
Hi, Snip I have created a soaring flight software comparison web page which may help you decide. It is available he http://www.soarmn.com/cumulus/software-ppc.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com Great chart! SeeYou now has a free product called ConnectMe to up/download flights/waypoints/tasks/declaration to many loggers, so you may wish to update the chart. While it is standalone from Mobile SeeYou (even users of other products can have it free) I see it as 'part' of that product. a href="http://connectme.seeyou.ws/"http://connectme.seeyou.ws//a Bob |
Thanks Guys I have strepla demo and will get the others to test.
Paul what cable can I use between the Volkslogger and the Navman PIN I have a discount certificate that came with my Volksloger do you give the discount as well Paul ? Mal "Paul Remde" wrote in message news:hzcrd.118507$V41.113826@attbi_s52... Hi, I sell and support StrePla. It shines in regard to maps and in-flight optimizations. WinPilot is excellent software as well. I don't sell WinPilot but I have flown with it in the past. I have not tested either product on the Navman Pin but you could install the demo versions of each product for testing. You may also want to consider SeeYou Mobile and Glide Navigator II. Those are the 4 most popular options. I have created a soaring flight software comparison web page which may help you decide. It is available he http://www.soarmn.com/cumulus/software-ppc.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... I have purchased a Navman pin has built in Gps Have a Volkslogger but no need to connect it to the navman pin. I will be using it in Australia what is the better of the two. Mal |
Hi Mal,
It is my understanding that the Navman PIN has an internal GPS so you shouldn't need a cable to connect to an external GPS. I can sell StrePla to you at the discounted price if you have the voucher that came with the Volkslogger. Paul Remde "Mal" wrote in message ... Thanks Guys I have strepla demo and will get the others to test. Paul what cable can I use between the Volkslogger and the Navman PIN I have a discount certificate that came with my Volksloger do you give the discount as well Paul ? Mal "Paul Remde" wrote in message news:hzcrd.118507$V41.113826@attbi_s52... Hi, I sell and support StrePla. It shines in regard to maps and in-flight optimizations. WinPilot is excellent software as well. I don't sell WinPilot but I have flown with it in the past. I have not tested either product on the Navman Pin but you could install the demo versions of each product for testing. You may also want to consider SeeYou Mobile and Glide Navigator II. Those are the 4 most popular options. I have created a soaring flight software comparison web page which may help you decide. It is available he http://www.soarmn.com/cumulus/software-ppc.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mal" wrote in message ... I have purchased a Navman pin has built in Gps Have a Volkslogger but no need to connect it to the navman pin. I will be using it in Australia what is the better of the two. Mal |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 06:40 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 06:40 PM |
| Small Sheriff's Departments Using Helicopters | Gig Giacona | Rotorcraft | 23 | September 7th 03 10:52 AM |
