Help.
I want to repair some self-inflicted wounds on the leading edges of the wings on my LS1-d. The wounds were created when getting the wings out from and/or putting them back into the definintely non-Cobra/Komet trailer. While not a Cobra, it is a 'serpent' type of trailer, but more of a intestinal 'tape worm'... I scraped off little bits of gel coat from time to time and I want to reapply gel coat. Fill the little divots and sand them off. But, how do you sand the leading edge? These divots were probably no more than about 50 mm long for the largest and no more than about 10 mm high, again for the largest. Others are smaller. And, they are right on the nose of the leading edges. I've begun the work with some gel coat and I've sanded it down, but wondering what the 'right' way would be. What size sanding block to use? I'm using a milled piece of wood that measures about 75mm wide by 15 mm thick by about 450 mm long and wrapping a sheet of sanding paper around it. My sanding movements have been parallel with the leading edge, trying to keep the sand paper right over the gel coat which 'stands proud' above the surrounding areas. Any help will be appreciated. Thanks, Ray Lovinggood Carrboro, North Carolina, USA |
| Thread Tools | |
| Display Modes | |
| One coat paint for aluminum? | tompet@peak.org | Home Built | 10 | September 17th 04 08:01 AM |
| Repairing gel coat chips | Gary Evans | Soaring | 6 | April 27th 04 04:23 AM |
| Water-borne barrier coat | larsen-tools | Home Built | 0 | February 3rd 04 09:42 PM |
| Refinishing: Who has tried a shortcut? | Ian Forbes | Soaring | 60 | December 26th 03 10:30 AM |
| Poly paint | Miguel Lavalle | Soaring | 18 | October 30th 03 09:55 PM |
