Panel volt meter
Old January 13th 05, 12:00 PM
GeorgeB
On 12 Jan 2005 21:10:02 -0800, "ContestID67"
1) The meter is only 0-1vdc so you have to add a two resistor bridge to
scale the input range you need. The instructions tell you how.
2) There is no scale on the meter, just red/green markings.
3) There are three wires. Ground, a +5 to +12vdc supply to power the
meter and a sense line.
The meter can also be wired to read current by using it to measure the
voltage across a fixed 1% resistor. E=IR comprende?
Yes, that works, but a 1 volt drop for full scale is a lot on a 28V
system, and even more on a 14V system (use 24 and 12 in this sentence
if it makes more sense).
NORMALLY, a meter used to measure courrent won't have but about 50mV
or 0.1V drop at full scale ... try to find something lower if you want
to read discharge currents. If this is a motorglider with electric
start, the resistance of the battery cable is often enough to develop
enough drop for this 1V meter ... for starting current. In testing
ground based circuits like this, I will often clip on the crimp on
each end of the cable. Absolute, no ... relative, yes, and
repeatable. It can be calibrated.
Nimbus 21C instrument panel Bill Daniels Soaring 10 October 13th 04 12:52 PM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 02:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 03:45 AM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 04:41 PM
