Panel volt meter
Old December 22nd 04, 05:47 AM
Bob C
Default Panel volt meter
I just found a really nice panel volt meter. It is
7/8' X 1-3/4' X 1/8'. Weighs nothing. It needs a
single 7/32' hole for mounting. The wires run through
the single hollow mounting stud to the rear of the
panel. Really slick! 2 wires (+V & ground). Reads
4V to 25V. It's from Lascar Electronics. Model #
EMV-1200. Cost is $25.00
They also have a hobbs (hour) meter. Same size & price.
Reads either total time or trip time. Could be useful
for keeping track of flight times.
www.lascarelectronics.com
Bob C.
Old December 22nd 04, 10:56 AM
TOM RENT
I have that exact panel voltmeter on my panel in my Glider. It is great to
know how the battery is doing as the hours tick by, as well as part of the
preflight/pre-takeoff check. You can also see how deep the battery drops
when you transmit on the radio. Well worth putting one in.
Tom Rent
Minnesota Soaring Club
Old December 22nd 04, 02:59 PM
Jim Vincent
Had one in my panel for a few years now. Also available from Allied
Electronics at www.alliedelec.com. Just search for EMV 1200.
I have it a little placard to sort of indicate remaining capacity. 100% =
12.7V, 75% = 12.4V, 50% = 12.2V, 25% = 12.0V, 11.9V = 11.9V.
Jim Vincent
N483SZ
illspam
Old December 22nd 04, 05:06 PM
ContestID67
Wow that is a very nice item. Small, each mounting and wiring, and LCD
so very visible under bright light conditions. For those in the US,
the Lascar site is in the UK. There are several US companies that
stock the item such as http://www.alliedelec.com. Search for
"EMV1200". Note that there is also a "EMV1200-40" which is more
expensive and goes up to 40VDC. The EMV1200 only goes to 20VDC which
is fine by me. Thanks for puttting me onto this item.
Old December 22nd 04, 05:14 PM
ContestID67
Another comment. The EMV1200 goes to 25VDC. It also only draws 3ma
which means that it can safely be on all the time. My Cabridge 302 can
display battery voltage also but it is 1) a little difficult to get to
when flying and 2) I'd rather have a dedicated display. Thanks Again.
Old December 22nd 04, 07:16 PM
Eric Greenwell
3 ma is 1 amphour after only two weeks, or 15% of the typical 7 amphour
battery. I suggest it be wired in after the master switch instead of
left on all the time. If you routinely remove your battery when you
aren't flying, then the drain isn't a probem.
Eric Greenwell
Washington State
USA
Old December 22nd 04, 06:40 PM
Bob K.
I installed one of those EMV-1200 units a few years ago when I flew my
first GPS (that is, non-photo) contest. I'd read about it here on RAS
and ordered it from Allied.
It went in really easy (I just pegged the wires down under the
appropriate screws on the panel terminal strip), works good, and looks
good. I'll get another for my next glider.
Bob K.
http://www.hpaircraft.com
Old January 7th 05, 03:17 AM
keithw
If you have a Colibri it will also give you the voltage readout .
keithw
Posted via OziPilots Online [ http://www.OziPilotsOnline.com.au ]
- A website for Australian Pilots regardless of when, why, or what they fly -
Nimbus 21C instrument panel Bill Daniels Soaring 10 October 13th 04 12:52 PM
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) Heiko Brandstaedter Simulators 0 October 7th 04 02:42 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 03:45 AM
Air Force Museum forms review panel Otis Willie Military Aviation 2 August 29th 03 04:41 PM
