On Friday, August 2, 2019 at 2:10:38 AM UTC-4, John Foster wrote:
On Thursday, August 1, 2019 at 8:09:20 PM UTC-6, Bruce wrote: Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each. So which pins did you end up using? The "bobbie" pins or other? Enquiring minds want to know ![]() Bruce If you have Facebook, check this link out: https://www.facebook.com/photo.php?f...type=3&theater "Sorry, this content isn't available right now The link you followed may have expired, or the page may only be visible to an audience you're not in." |
Source for L'Hotellier Safety Clips | George Haeh | Soaring | 23 | January 29th 19 12:20 AM |
L'Hotelier Fitting Safety Pins | Dan Marotta | Soaring | 20 | October 17th 16 01:40 AM |
Complete Hotelier Connections For Sale (Brand New) $400 | Scott Alexander[_2_] | Soaring | 2 | July 19th 12 10:40 PM |
Hotelier safety sleeves | [email protected] | Soaring | 6 | August 31st 07 03:41 PM |
Lycoming throttle linkages | Evan Carew | Home Built | 0 | September 29th 04 01:58 AM |
