FAA regulations - W&B
Old March 9th 05, 01:33 AM
BTIZ
"Arne" wrote in message
In USA, if you are flying under Part 91 of the Federal Aviation
Regulations (FARs).
Are you required to perform weight and balance checks before every flight?
yes, as PIC you are required to be aware of the w&B and effect of fuel burn
on CG inflight
And if so, are you required to document it?
No
Can the FAA show up on the ramp asking you to show the weight and balance
calculation?
No
Know your rights for "Ramp Checks", Yes, Here is my pilot certificate and
medical, and the aircraft POH is right here, but if you don't mind I'm
running late for an appointment and I need to get this aircraft secured. Is
there a phone number were I can call you and we can continue this
discussion?
BT
Old March 9th 05, 02:22 PM
OtisWinslow
My solution:
I keep several sample W/B spreadsheets in a notebook in
the plane. My loading most often follows one of them. No
need to recalc it then.
Regulations (FARs).
And if so, are you required to document it? Can the FAA show up on the
ramp asking you to show the weight and balance calculation?
Old March 15th 05, 01:32 AM
Margy Natalie
In the Navion with the geared engine if I was flying solo I had to put fuel in the
baggage compartment tank to stay within W&B. Ron was ok by himself, I'm just too
light : - ). We will see what the W&B looks like with the new engine.
Margy
George Patterson wrote:
Peter Duniho wrote:
Of course, in most cases, a pilot will have done enough sample W&B
calculations to know when they need to consider the "balance" part for solo
or lightly loaded operations.
This is not necessary with a Maule. You can load anything in the front seats up
to the point of MGW and stay within the envelope. This is also true of a Cessna
150. This is, in fact true of nearly every light aircraft.
I suppose you could argue that "enough sample W&B calculations" is 1 in those
cases, but I can't recall every doing any when I owned those planes. It was
pretty obvious from the fact that the front seats are right under the center of
lift.
George Patterson
I prefer Heaven for climate but Hell for company.
Old March 15th 05, 01:50 AM
Montblack
("Margy Natalie" wrote)\
fuel in the
just too
What's the update on your Navion?
Montblack
Same BA 747 loses engine again, Violated U.S. regulations Big John Piloting 3 March 8th 05 10:38 PM
Ultra light Glider regulations Denis G Soaring 5 May 24th 04 06:19 PM
ANN: WingX Version 1.2 - Federal Aviation Regulations on your PDA! Hilton Software LLC Piloting 7 October 17th 03 04:51 PM
New UK Regulations Soaring 5 October 2nd 03 12:13 AM
FAR:Safety Pilot & High Performance/Complex? John T Piloting 53 August 18th 03 04:04 PM
